Help please
Old Feb 6, 2011 | 06:14 PM
momo20's Avatar
momo20
Default Help please
my interior door lights and maps light are dead..the lil twlight a.k.a mystery light does come on however..i have checked fuses #2 and #29 both looked good..but replaced with new ones just to be sure..still dead....
my footwell lamps are still coming on..is there a chance #37 the relay could be dead? can those be replaced?
Old Feb 6, 2011 | 06:28 PM
robert miller's Avatar
robert miller
That are a shorted wire someway.
Old Feb 6, 2011 | 06:42 PM
ALLEGRO's Avatar
ALLEGRO
Swap the relays around and see if that solves THAT problem. If so you have found a bad relay.
Old Feb 6, 2011 | 07:25 PM
momo20's Avatar
momo20
Allegro do the relays just pull out? seems like they are pressed in there pretty good
Old Feb 6, 2011 | 07:37 PM
ALLEGRO's Avatar
ALLEGRO
You may have to use some pliers (carefully) but they just pull out.
Good Luck
Old Feb 6, 2011 | 07:39 PM
momo20's Avatar
momo20
ok i will try that..if the relay is bad lets say . do i have to special order that relay from the dearlship or do i can i get one at an auto parts store?
Old Feb 6, 2011 | 09:00 PM
momo20's Avatar
momo20
i switched out a few relays and checked fure #21 but nothing as of yet..from what i found is the pervious owner had a aftermarket alarm system installed and then removed it when it he traded it in....i think has something to do with that...it appears the system was taken out professional and all the connections i can see were done right...gonna do some research how to test a relay to see if its good or bad
Old Feb 6, 2011 | 09:11 PM
momo20's Avatar
momo20
also the hood liner is gone..and i think its due to the k&n filter syetem was rubbing the hood liner...new one is on order...so there is no hood light ..would having no hood light render the system not to work?
Old Feb 7, 2011 | 03:01 PM
momo20's Avatar
momo20
Well that would help explain that..so it has to be something stupid.
To Help please
