I've been through all the usual steps, as I could afford, and my confidence grew. So much for my bonifides.....
I'd recommend LT headers as my first mod, too. It's a base from which every other mod will benefit. As to major mods needed to achieve your goal of 450-550 hp, (I'll assume RW) then you need to decide first whether or not you're planning on using a power adder. If you're a die-hard all motor type of guy, you can achieve around 450 pretty easily, without getting into the shortblock. At this point, things start getting more difficult, and you have to support the extra HP with drivetrain parts that can take it, starting with a clutch. The simplest way to get the HP is a centrifical supercharger. For about $4500-7500, depending on kit, and DIY or not, you'll easily get 500, or more. This level is achievable NA, but it takes a perfect combination, and a generous dyno operator. If I had it to do over, I'd skip the heads/cam/FAST step, and go right to a power adder.
To get that power at the rear wheels you can go at least 3 different ways.
1. NOX, although many people do not recommend it.
2. Heads and cam. Costly, requires going into the engine, and may affect drivability.
3. Supercharger or turbochargers. Will cost more but will give you the best power increase without going into the engine.
With all of the above, you would benefit from a cold air intake and long tube headers. It would be somewhat pointless to not do them. Also, a better clutch would be a necessity.
And a larger throttle body and different intake could be beneficial.
It all really depends on your budget, what you want to do with the car, and your driving ability. If you cannot get all the car has to offer out of it as it is now then driving school would be a nice modification.
Enjoy the car for a year before you start adding power. It's a fast car stock. Get to know it and learn how to drive it. The weather will be getting nice soon and you shoud be driving it! I've had mine for 4 years and it's still stock and I've put about 40K miles on it. If I were to add power, I'd go with a blower. There's quite a few excellent products available. But drive it for through the summer and then make up your mind.
Unless you are going to roadcoarse much, I'd go right for a Centri Supercharger (great for street cars or drag cars.) You can gain 150+ hp with just that, and not have to change hood as with a screw style blower. And significantly cheaper than most turbo kits. You can spend just as much on full bolt-ons + heads, cam etc. and still not end up with near the power output of just bolting on a centrifugal blower in the first place.
That is actually my plan as well. It's great in its pure stock form (aside from some tint on the windows), and after a year I should know if I even want to do anything, and if so, should hopefully have a good idea what to do. So this post is a great head start for making those fun decisions in a year from now.
I thought about the idea of "learning to drive it as is", but decided that I did not want to learn to drive it twice. I bought my Z and put C6 rims and nitto tires on it the first week I had it. The second week it went to the shop. It has headers, cam, cai, ported TB, UD pulley and tune. It made 425rwhp. Now I am learning to drive it once and I get better every time I get in it.
Good point, that's kind of like telling someone in the market for a C6Z or a ZR1 that they need to learn on a C5 first.
Assuming the car has new/almost new plugs,wires,fuel regulator,all fluids have been changed...this is what I suggest (and did to my 02Z).
Add a CAI,Street tune,Short shifter,Upgrade the shocks,brakes and tires.Improving your driving skills is always a good mod.
Enjoy this level for several months( I stopped here)......IF you need more horses,go with headers,cam,heads...and don't forget to upgrade the clutch,trans & diff if needed.
This should be 450 easy......
As always,IMO.Opinions & Results vary.
\db2
carolina
I guess every person has their own pace that feels the most comfortable. I started with a base C4 way back in 1990 and it was all the car I needed at the time. 3 years later I was looking for more punch and in 93 bought a Base C4 with a 383 Lingenfelter package pushing out 440 HP. That put a smile on my face for almost 18 years! So I don't mind learning to drive a corvette 2 or 3 times ... or 4 or 5 or ... anytime I get to drive a vette I am pretty happy.
Bolt ons....exhaust, intake, tune...then do a s/c!
Curious why you suggest doing the bolt-ons first?
When an A&A kit on a bone stock C5Z will put out around 520 at the wheels (approx. 590hp engine horse power.) If the OP would be satisfied with that power level wouldn't the bolt ons be a considerable extra expense?
I only drive it on non-work days or special events. (Less than 9k a year.) It may seem like an odd set-up, but I run Nitto NT05R up front, and Nitto 555RII in the rear. I have 380 tq to the tires and I cant break them loose. High speed handling stays planted as well. I may go with new fronts though when they wear down.
1. Tires (Drag Radial/High Performance Summer Tire; these are a must) ($300-600)
2. Longtubes/Midpipe ($800-1600)
3. Vararam/Intake of your choice ($400-500)
4. Short shifter and a Tune (SS = $150-300) (Tune = $600)
*** At this point you can decide which of the following routes you'd like to go, most of your mods will transfer over (unless you go turbo...ect)***
[x] Route 1: Bolt-on Supercharger & Clutch ($4000-$6000+) [depending on where you go and if you do the work yourself/ or what deal you can get]
[x] Route 2: Install a Cam/Heads Combo ($3000-$4000+) [depending on where you go and if you do the work yourself/ or what deal you can get]
+ Route 2a: Add nitrous/clutch to the combo ($500-????)
[x] Route 3: Install Nitrous & a Clutch ($1500+)
[x] Route 4: Go all out and get a TT kit ($7000+)
Either route will get you to the power you desire, its all about how much you wanna spend and how reliable you want things to be. Also depends on your preference (some people love the N/A Power, some love S/C)
