Rear end jacking question
Old Feb 11, 2011 | 05:52 PM
meflyfrc's Avatar
meflyfrc
Couple YouTube clips
http://www.youtube.com/watch?v=LHGcxCwMe5w
http://www.youtube.com/watch?v=vnDLko-fFLs
Old Feb 11, 2011 | 06:04 PM
SCM_Crash's Avatar
SCM_Crash
Perfect!
I need to go get some hockey pucks. I keep forgetting to do that. Been using a piece of woo for the front area, but that's not so possible on the back side areas.
Old Feb 11, 2011 | 06:28 PM
Vettmann17's Avatar
Vettmann17
Great Vid's, Thanks!
Old Feb 11, 2011 | 06:54 PM
Pewter Scooter's Avatar
Pewter Scooter
Where is the best place to get pucks like those?
After I posted the question, I found one source on the YouTube page. Is there a better place to get them than TPSMotorsports.com?
Old Feb 11, 2011 | 07:01 PM
Oldvetter's Avatar
Oldvetter
I use a pressure treated 2X6 (they are harder) under my rear support. Even with my low profile jack, I need to jack up one side of the car with a second floor jack and a jacking puck to get the jack under the rear.
A 2X6 is very close to width of support, you need to check it before jacking up.
BTW, jacking rear up higher only drains 4 ounces more oil, but I do it anyway.
Old Feb 11, 2011 | 08:02 PM
meflyfrc's Avatar
meflyfrc
I made my own.
Pucks from Play It Again
Eyes screws from Home Depot
http://www.digitalcorvettes.com/foru...d.php?t=119932
Old Feb 11, 2011 | 08:38 PM
imavettegirl's Avatar
imavettegirl
for 4 ounces or less i will keep jacking only the front for an oil change.
i do let the jack down with the bolt out of the oil pan and let whatever is left dribble out.
i will not lose any sleep if there still is an ounce or so left.
Old Feb 11, 2011 | 09:25 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Originally Posted by imavettegirl
why are you jacking up the rear to change the oil?
To change the oil you have to jack up the front and the rear with the rear being just a bit higher.
Old Feb 11, 2011 | 09:44 PM
imavettegirl
refer to post #27.
Old Feb 11, 2011 | 10:04 PM
Mr.Bill's Avatar
Mr.Bill
refer to post #27.
My post wasn't a reply to #27, It was to your one before........
Old Feb 11, 2011 | 11:25 PM
Pewter Scooter
Originally Posted by meflyfrc
I made my own.
Thanks meflyfrc... That saves me a lot of $$$
I'll make my own!
Old Feb 12, 2011 | 12:46 AM
wetelvis's Avatar
wetelvis
I use a low profile but to get the clarence drive the car onto some 2x10 s . For the cross member I use 2x6 about 21 inchs long with 2x6 blocks where the jackstands sit.
Old Feb 12, 2011 | 12:49 AM
  #33
wetelvis's Avatar
wetelvis
Oh yeah screwed together too.
Old Feb 12, 2011 | 12:50 AM
  #34
thisMSGgood4me's Avatar
thisMSGgood4me
Here's what I use - a low profile floor jack and I had an 8"x8" piece of 1/4" steel cut. No worries about wood splitting and it is big enough to cover the entire width of the crossmember.
Are you sure 8" is wide enough to provide support under the 2 lift points as shown in the diagram DeeGee posted (#3)? I thought those 2 lift points are wider apart than 8". I use a 2x10 about 20" long, and it's wide enough to support the crossmember under the 2 lift points.
