Tail light seals
Old Feb 11, 2011 | 11:28 AM
JohnnyDee's Avatar
JohnnyDee
2023 C7 of the Year Finalist - Modified
2019 C5 of Year Finalist (performance mods)
2017 C5 of the Year Finalist
Default Tail light seals
I have flush mounted tail lights and need some help with what seals work. The tail light recesses have a taper to them, so when you flush mount them it creates more space around the light than if they are recessed. Does anyone know if the tail light seals that Southern Car Parts sells will take care of that extra space. I contacted them and they weren't sure. If your using something else what is it? Thanks for any info anyone can provide. JD
Old Feb 11, 2011 | 11:52 AM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
DIY tip.
Just go to Lowes or Homedepot and pick up some weather stripping, For like 9 bucks you can get enough to do 4 cars.
Old Feb 11, 2011 | 12:03 PM
99 VET's Avatar
99 VET
Oldtimer
St. Jude Donor '13
I agree with Mr Bill. Suggest you have the ends meet at the top (less visable & less likely to allow moisture in). Good luck!
Old Feb 11, 2011 | 01:21 PM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
I've seen various vendors offer these seals and never really thought I had an issue with drips, etc.
When I wash my car, I use an air gun to blow out any water from the rear lights, side mirrors and door handles/locks which tend to be the primary areas the water tends to hide.
Any other reason for these seals? Do they help protect the wiring, etc.?
Old Feb 11, 2011 | 01:53 PM
Joe Babe's Avatar
Joe Babe
weather stipping works & it cost a lot less,or a blower does the trick
Old Feb 11, 2011 | 02:18 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
Originally Posted by Mr.Bill
DIY tip.
Old Feb 11, 2011 | 02:37 PM
Mr.Bill's Avatar
Mr.Bill
I had flush mounted lights with the seals and after a few months I took the seals off and put the tails back to stock location, I didn't like the flush look. And no issue with water.
Mr.bill
Old Feb 11, 2011 | 02:45 PM
Daddyrama31's Avatar
Daddyrama31
DIY tip.
Old Feb 11, 2011 | 04:02 PM
99 vett babycar's Avatar
99 vett babycar
my tails are in stock position and Lowe's took care of the seals - $5.43.
To Tail light seals
