codes
Old Feb 11, 2011 | 05:19 PM
newyorknick's Avatar
newyorknick
Default codes
my 2000 coupe shows a code on the dic....10 PCM P0440 H C ...what does indicate.....thanks in advance......i have a code list but this one is not on my list
Old Feb 11, 2011 | 05:22 PM
dougbfresh's Avatar
dougbfresh
Search is your friend:
http://forums.corvetteforum.com/c5-t...0440-code.html
Old Feb 11, 2011 | 05:24 PM
Kevin Kuse's Avatar
Kevin Kuse
P0440 H = History
Make sure you gas caps on tight, Clear Code and see if it repeats.
CIRCUIT DESCRIPTION
The PCM tests the EVAP system for the following conditions:
Large and small leaks
Excess vacuum
Purge flow during non-commanded conditions
Fuel level and fuel pressure sensor faults
EVAP purge and vent valve faults
The PCM monitors the fuel tank pressure sensor in order to determine the level of vacuum/pressure in the EVAP system. The PCM commands both the EVAP Purge Solenoid and the EVAP Vent Valve ON when the conditions for running the DTC are met in order to apply an engine vacuum to the EVAP system. The PCM commands the EVAP purge solenoid OFF once the system has reached a predetermined level of vacuum. This test verifies if a vacuum can be achieved in the EVAP system. Failure to develop a vacuum may be caused by a large leak or a restriction. This DTC sets after twice failing the above test.
To codes
