[Z06] potential buyer
Old Feb 11, 2011 | 11:06 PM
matt0515's Avatar
matt0515
4th Gear
Default potential buyer
hey all, hows it going? name is matt, and im 25. im looking to go purchase a torch red 01 z06 tomorrow with 28,xxx miles on it from a local dealer. They are asking $18,500 for it, car history comes back with no issues.
Is there anything particular I need to look out for when looking this thing over? Price seems pretty reasonable. My dad has an 02 EB z06 w/ 9k miles and I love the hell out of that car. I realize some things were different on an 01, but most of what I've read won't remain stock anyways over time.
Bear with me, any help is appreciated. Thanks.
Old Feb 12, 2011 | 02:46 PM
Kmcoldcars's Avatar
Kmcoldcars
Look the car over carefully. Make sure it looks like a 28000 mile car. Check the rubber around the windows and trunk lid for any evidence of paint overspray. Also check in the engine compartment. Check the doorjambs for the same and for indications of sanding scratches in the paint. Look at the bottom of the rocker panels for cracks or other damage. Check the color and clarity of the clutch fluid. Find out if the coolant has been changed. Check the date code on the tires. If they are originals they need to be replaced. If everything looks good and the car appears to have been well maintained, then go for it.
Old Feb 12, 2011 | 02:53 PM
imavettegirl's Avatar
imavettegirl
take your dad when you go look at it.
Old Feb 12, 2011 | 03:22 PM
EPMM 03 C5's Avatar
EPMM 03 C5
Matt, best of luck to you! I looked for 5 months before i bought my Z06 last march. I try to drive the car daily and love every minute of driving the beast!
Old Feb 12, 2011 | 03:23 PM
VCUFAN's Avatar
VCUFAN
Definitely look it over carefully, seems a little low for a dealer. Hope it works out for you.
Old Feb 12, 2011 | 03:26 PM
MawneeC5's Avatar
MawneeC5
Since your dad has one, he should be able to spot something "off" easily with a quick drive.
If that car is in good condition that is a really good price.
Old Feb 14, 2011 | 06:15 AM
matt0515's Avatar
matt0515
4th Gear
well, shouldve known better. car had more like 75k worth of wear and tear. i passed. id rather spend more on the right one. ima hold off for a bit but ill keep in touch bc eventually ill be a regular on here!
thanks guys.
Old Feb 14, 2011 | 07:54 AM
BobG's Avatar
BobG
thanks guys.
Sounds like you made a smart decision. However, you should be a "regular" here now, rather than later. You should spend a lot of time reading the C5 Z06, General, and Tech section, as if you sort through the overly abundant ads, you can get a real feel on the issues these cars face.
Another section you should be really watching is the C5 for sale section. Buying from a fellow enthusiast has a lot of benefits. Plus, you can search on, and read their posts, that way you can get a more accurate picture of how the car was driven, cared for, and any problems it might have had. You are less likely to be "surprised" that way.
Old Feb 14, 2011 | 08:31 AM
matt0515's Avatar
matt0515
4th Gear
good point. ill stick around and post more often, thanks!
Old Feb 14, 2011 | 10:19 AM
Z06X's Avatar
Z06X
18.5k from a dealer for a low mile z06...I figured something wasn't gonna add up.
Like the guy said above, spend your time on here reading around and searching to learn more about the cars. I'm still waiting to pick up my Z06 in the middle of March, but spend plenty of time reading about things I want to address to stay ahead.
Old Feb 14, 2011 | 12:39 PM
IMXCITD's Avatar
IMXCITD
yep....jjust watch and wait for the right Z to come along. You will be happy you waited for the right vette!
To potential buyer
