Is the LS1 engine washable?
Old Feb 16, 2011 | 07:58 AM
  #41
09 R. Glide's Avatar
09 R. Glide
3rd Gear
I've washed mine several times ,but for some reason the air does not work for a couple of days after I've washed it .seems that what ever that gets wet has to dry out before the air will work agin .anyone know what might be the cause of this ?
Old Feb 16, 2011 | 02:00 PM
  #42
Too-Fast's Avatar
Too-Fast
Active Streak: 90 Days
2024 C6 of the Year Winner - Modified
Originally Posted by Rohan
After my Z gets out of the paint shop I'm going to try this method. I can see the definite plus side of no water. I'm from Florida and we get flash rain showers and there is sand everywhere. Will this method work in that environment?
I lived in Palm Harbor, FL (near Tampa) for seven years and used the same methods.
Old Feb 16, 2011 | 09:09 PM
  #43
versatile's Avatar
versatile
Originally Posted by outwest nv.
This looks like Randy, the Trailer Park's Assistant Weekend Manager! If you've ever seen Trailer Park Boys, then you know what I'm talking about. This show was so bad it was great!
I don't recall Randy drivin a Z06! LOL
Old Feb 17, 2011 | 04:19 AM
  #44
SCM_Crash's Avatar
SCM_Crash
I've pressure washed my motor once because it had a lot of coolant all over the place after I had an overflow issue. However, since that day I've kept it up really easily with some good trim polish. No need to pressure wash it if you keep it maintained.
Do the pressure wash, but take the warnings into consideration. Don't take the fuel rail covers off while pressure washing. When you're done, pull the fuel rails off and wash them separately with either simple green or actual car wash soap. While the covers are off, use a damp rag to wipe down the intake manifold and cross bar.
I use trip polish on the fuel rail covers, intake manifold, reservoir covers, radiator shroud, brake booster, window wipers and the trim piece that goes below the windshield that the wiper blades rest on.
As you can see, the engine bay looks as clean as it would have brand new from the dealer (with the exception of the upper radiator hose - in this pic. LOL) Also, notice the trim piece below the windshield looks brand new. Normally this looks dulled or grey. They often have oxidation on them. This one does not because I use trim polish. I'll take a better shot if you'd like. But this is a VERY clean engine bay and believe me, this car is driven more than 1000 miles a month.
Flash on the camera turned on:
Old Feb 17, 2011 | 09:56 PM
  #45
Rebel 1's Avatar
Rebel 1
Very nice! How in the world did you get the alternator/brackets to look so new? Also what is trim polish?
Old Feb 17, 2011 | 11:10 PM
  #46
99torchredlb's Avatar
99torchredlb
The only problem I have is trying to get it the dryer............
Old Feb 18, 2011 | 01:58 AM
  #47
SCM_Crash's Avatar
SCM_Crash
The aluminum cleans up easy with water and a small amount of car wash soap. You can also use a small amount of dish soap for the metal surfaces, but I just use water. A little scrubbing and it all comes off easy.
I use Meguiars "Ultimate Protectant: Dash and Trim Restorer" as the trim polish, but there's lots of them out there. No greasy residue or film left behind too! I don't use this stuff on my dash, though. In fact the only interior component I used it on was the trunk hatch (FRC) to get the the oxidation off, which worked perfectly. But I don't put this on any interior pieces, especially ones that are vinyl or anything that sees the light of the sun.
I use a lightly damp cloth to dust my interior.
Old Feb 20, 2011 | 12:00 AM
  #48
RIJVETTES's Avatar
RIJVETTES
Originally Posted by Virtual Geezer
Not sure if this is what happened to the OP's LT1 engine, but the Opti-Spark optical distributors were very susceptible to water -- especially the '92 and '93 models. If you fried one, the unit itself was fairly expensive and required quite a bit of labor to replace.
Yes, the opti spark distributor on the early C4's was the problem with water intrusion and no place for it to go. I had a 93 and frequently washed the engine compartment, but carefully wrapped plastic bags around the opti spark and electrical. Never had a problem.
For the C5, I do about the same, with Simple Green and a hose and rag. However the engine compartment is better sealed and seems to stay cleaner than the C4.
