98 corvette
Old Feb 12, 2011 | 05:46 PM
vinnys65's Avatar
vinnys65
8th Gear
Default 98 corvette
wheel bearing ??noise only 57k been sitting 2years, car was smooth when parked , now about 2 years later it has a real hum noise sounds like a wheel bearing......is this common.....or maybe something else?????thanks vince no codes at all, everything else seems great??????????????????????
Old Feb 12, 2011 | 06:24 PM
imavettegirl's Avatar
imavettegirl
more info?
Old Feb 12, 2011 | 06:25 PM
themonk's Avatar
themonk
From: Calgary, AB. There's a reason why white was the only color offered on every year Corvette. Proud Canadian German Jamaican!
St. Jude Donor '09, '12-'13-'14-'15-'16-'17
and..............
Old Feb 12, 2011 | 06:39 PM
vinnys65's Avatar
vinnys65
8th Gear
car has been sitting about 2 tears ,started driving it again and its real noisy, can't think of anything else???????
Old Feb 12, 2011 | 06:41 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Throwing any codes? Any maint when you brought it out of storage?
Old Feb 12, 2011 | 06:54 PM
vinnys65's Avatar
vinnys65
8th Gear
no not at all , everything else is good, the humming noise sounds like a bad wheel bearing , didn't know if any one else has had this problem????
Old Feb 12, 2011 | 07:01 PM
killain's Avatar
killain
Oldtimer
Default vague info
How about any leaks on the spot where it sat for two years? How about putting it up on a lift and checking the Transmission and differential ? and I'd check to see if anything is loose with the rear hubs and axles ?
Old Feb 12, 2011 | 07:05 PM
vinnys65's Avatar
vinnys65
8th Gear
no leaks , all fluids good , axles feel tight , going to pull wheel tomorrow , just seeing if any body else has had this problem
Old Feb 12, 2011 | 07:12 PM
doublec4's Avatar
doublec4
Sitting and not moving for 2 years isn't great for wheel bearings. Could be a bearing.
Old Feb 12, 2011 | 07:14 PM
vinnys65's Avatar
vinnys65
8th Gear
that was my thinking to, looking to see what others thought...thanks vince
Old Feb 12, 2011 | 07:28 PM
imavettegirl
the tires are probably flat spotted.
the rotors and brake pads and calipers should be looked at.
c5BlackBeauty
Lifetime Member
I would guess bearing as well.....but you may want to peruse the following posts from the Tech Forum. Good luck.
http://forums.corvetteforum.com/sear...rchid=22156087
Old Feb 12, 2011 | 07:39 PM
vinnys65's Avatar
vinnys65
8th Gear
ok thanks .......
To 98 corvette
