AM Radio Static
Old Feb 20, 2011 | 12:55 AM
jacks996's Avatar
jacks996
Jacks996
Cruise-In VIII Veteran
I have not used AM since 1975
Old Feb 20, 2011 | 09:55 AM
runner140*'s Avatar
runner140*
Originally Posted by molson
I had the same issue on my car.
Try unplugging the rear defrost connection @ the back window.
Solved it for me.
Had just purchased the 2000 and as soon as the sun come up, no AM radio....Someone posted the same problem and the answer was to disconnect the two rear defrosters. That was almost four months ago..... and now I get great reception on AM and FM. Problem solved BUT I live in south Florida and we don't need any defrosters.
Old Feb 20, 2011 | 10:26 AM
Fast one's Avatar
Fast one
Metallic window tint over an antenna in glass window can reduce AM reception, the more expensive carbon tint allows more of the signal to hit the antenna. Does your car have aftermarket window tint?
Old Feb 21, 2011 | 10:24 AM
KeithAllen's Avatar
KeithAllen
5th Gear
All original.
Old Feb 23, 2011 | 04:12 PM
KeithAllen's Avatar
KeithAllen
5th Gear
I disconnected the rear defroster, but that didn't help. But I have noticed something unusual when driving on different surfaces. There seems to be more static on concrete paved roads that blacktop. Is it possible the belts in the tire are giving off some kind of signal and then transmitting it through the TPS to the radio? I replaced the Goodyear tires about 3K ago with Firestone Firehawks run flats but I had the noise before that. Any more thoughts or ideas would be appreciated.
Old Feb 25, 2011 | 09:47 PM
docohm's Avatar
docohm
Solved it for me.
This worked for me too, mine 2001 Coupe had very bad static only on AM when I got it 5 years ago. I tried this and that and finally found that when I pulled BOTH the wires on the rear defrost it all cleared up.
Don't need that defrost anyway!
