Fuel Gauge Issue
Old Feb 20, 2011 | 09:39 PM
Lemi's Avatar
Lemi
Default Fuel Gauge Issue
My problem is that even with a full tank of fuel, out of no where, the gas gauge will drop to empty while driving. After shutting off the ignition and than turning it on again the gauge will work fine for a while and go to zero again. Additionally, I am smelling an odor of gas fumes. Thanks in advance.
Old Feb 20, 2011 | 09:47 PM
slvrzo6's Avatar
slvrzo6
The Fuel gauge problem can easily be fixed by adding a bottle of Techron to your Gas Tank. Many have had this problem and this usually resolves the problem. Techron can be purchased at Autozone or other auto part stores. As far as the Fuel smell?? Can you pinpoint where the odor is comming from. There have also been several members with crack fuel crossover lines.. Don't know if this is your case, But it's seems to be happening more frequently as these cars age.
http://forums.corvetteforum.com/c5-g...or-smells.html
Old Feb 20, 2011 | 10:59 PM
Dale002's Avatar
Dale002
Usualy works.
Old Feb 20, 2011 | 11:05 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Another Vote for Tezchron fuel additive
Thanks,Matt
Old Feb 20, 2011 | 11:45 PM
Z06ster's Avatar
Z06ster
The fuel gauge problem is unfortunately a common problem for C5's. The problem is not with the gas gauge itself but caused by corrosion of electrical traces on the fuel level sensors, which are part of the fuel sending unit assemblies. Basically a manual arm is driven by a floatation device inside the tank. There are two tanks, passenger side and driver side. The contacts on the manual arm traverses a circuit board, modulating the fuel level information to an electrical signal.
With regret, you can't replace the fuel level sensors by themselves. You need to purchase the entire sending unit assembly. I see many here comment that techron reverses the effects of the corrosion. While I wish you luck with techron, it didn't work for me and I ultimately had both passenger side and driver side fuel sending units replaced. Everything works great after that. Certainly try your luck with the Techron first and I wish you luck.
Since I knew about this problem, I had the dealer remove the fuel level sensor from the fuel sending unit and snapped this picture of it. You can see the black corrosion on the traces. Those traces should be as shiny as a new silver dollar,
Old Feb 20, 2011 | 11:52 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
It may take 2-4 bottles to work make sure you wait till the tank is below 1/3 to add and fill up so it mixes well and crosses over to the 2nd tank. It takes time for it to work and the arm going up and down over the corroded area. This always seems to happen ~ 3/4 of a tank. You may also notice when full the gauge only shows 7/8. When fixed full is over F. Also use the 20 gal bottle of Techron.
To Fuel Gauge Issue
