[Z06] Headlight issue!!!
Old Feb 21, 2011 | 03:48 PM
Rocket13's Avatar
Rocket13
Default Headlight issue!!!
Howdy,
I got a speedwhite z06 and recently the driver's headlight started to make a noise when it goes down. Both headlights work perfectly, they go up and down at the same time. However, after the driver's headlight has gone down, the motor seems to be working still and makes a sound that lasts for only 4 sec. This sound is annoying and would like to fix that.....do not have the money to take it to the dealership and get it fixed since I know for sure they will try to replace the whole motor, although this might not be the case.
Old Feb 21, 2011 | 04:20 PM
RedZMonte's Avatar
RedZMonte
Look at his post and see if it is what your experiencing:
http://forums.corvetteforum.com/c5-g...orialized.html
Hope this helps:
S
Old Feb 21, 2011 | 04:39 PM
Rocket13's Avatar
Rocket13
Hope this helps:
S
WOW thank you so much. That's exactly the problem that I have.
To Headlight issue!!!
