!@#%&*pass mirror
Old Feb 24, 2011 | 12:47 PM
BRKLYN's Avatar
BRKLYN
Default !@#%&*pass mirror
Is it easy to fix? It just flops, tired of using double side tape to keep still and proper. Anyone chime in!
Old Feb 24, 2011 | 12:55 PM
Antvette's Avatar
Antvette
Veteran: Marine Corps
Hope this helps.
http://www.vetteweb.com/tech/vemp_07...placement.html
Old Feb 24, 2011 | 12:56 PM
rpm462's Avatar
rpm462
It's fixable, not sure how easy it is since haven't had to do it myself yet but here's a couple DIY threads on it.
http://97vette.com/howto/mirror/index.html
http://forums.corvetteforum.com/c5-t...n-swivels.html
Old Feb 24, 2011 | 01:08 PM
BRKLYN's Avatar
BRKLYN
thank you. I will read and get ready for the fix. At this time I dont even care if it swivels again.
Old Feb 24, 2011 | 05:00 PM
Thanks for the links. Saved them for future reference.
Old Feb 24, 2011 | 10:42 PM
GHL4505's Avatar
GHL4505
The mirrors on the C5 are not very good. Just a quick tap and they hang loose and flop. I've had two C5's they both had the floppy mirror syndrome. I fixed them . . . not the right way, but it worked for me.
I took a tube of clear silicone adhesive, swiveled the mirror. Dumped some silicone adhesive in the base. Moved it back into the right position, wiped the excess sicone off. Taped it in place and let it sit for 24 hours, then removed the tape. Was just going to be a quick fix until I bought a new mirror, but just never got around to getting a new mirror.
It's been about three years and still works great. One of these days, I'll get a new mirror.
Old Feb 24, 2011 | 11:23 PM
Gr8Wht's Avatar
Gr8Wht
CF Veteran
St. Jude Donor '10-'12, '25
Knock on wood...my mirrors are still intact! Thanks for the links. Good luck!
Old Feb 24, 2011 | 11:27 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
They part out cars every day in the parts section. Some even have mirrors that work on them.
To !@#%&*pass mirror
