Another HID problem thread. Sorry guys.
So here's the deal..
Went to install my HID kit today (35W kit, no pop ups, I have Spectre Werkes C5R lights) and I ran into a slight problem. I installed the driver side, turned the key to the ON position and it fired up properly. Passenger side still had the regular bulb and it worked fine as well. I thought "perfect, now I'll do the other side."
Next I installed the passenger side. Turned the key to the ON position, and the driver side lit up properly, but nothing on the passenger side. I figured it might not be getting enough juice, so I started the car. Once I did that, both sides were not working.
To rule out that the HID kit was the problem, I installed the entire passenger side HID assembly back on the driver side. It fired up properly with key in the ON position.
Not sure why only one side would work with the car off, and then neither side work with it on?
Thank you for any help you guys could give me!
Only thing that strikes me as strange is that why would the regular bulbs work then? The HID lights shouldn't draw anymore power? And if at least one works with the engine off, why would nothing work with the engine on?
I would check the connection to the passenger side to make sure the polarity is correct on the connection to the ballast. Most HID ballasts have the polarity reversed to the GM connectors.
I did read in another thread that the polarity can be mixed up but I figured if the one worked, and I did it the same on the other one, it should be fine. I'll reverse it on the one tomorrow.
If that fixes the lighting issue on the passenger side, any idea why it turned the driver's side off when I turned the ignition on? I'm stumped.
Try testing each side again but with the opposite side unplugged.
See if the passenger side fires up without the driver side ballast plugged in...
If theres one thing I hate troubleshooting, its electrical systems!
Thanks to everyone for all of the help so far. Hopefully get this rectified soon
So maybe it has to do with model year ? My jeep and vette are 2001.
Problem solved. It was the polarity issue. Turns out that only the polarity was backwards on the passenger side plug. Driver's side was correct.
Works with the engine on now too. Glad it wasn't anything that required more $$
Nice crisp 6000K light now:
You got be carefull when buying some of this electrical stuff to be sure that the connectors are correct.
Either way, glad to have it working properly
I'll give it a try in a few weeks when it gets a bit warmer outside!
By the way, I have to give you credit for all of the nice products you come out with. And on a side note, do you sell LED tail lights without the halo?
