new owner
Old Feb 27, 2011 | 01:19 PM
kenpvette's Avatar
kenpvette
Default new owner
i am purchasing a 2003 anniversary pkg vette thursday...i dont like the painted wheels...i beleive they are 17x8.5 up front and 18x9.5 rear..is this correct and can i put 17x9.5 front and 18x10.5 in the rear??and will the factory tires go on the wide wheels??
Old Feb 27, 2011 | 01:34 PM
RAT's Avatar
RAT
Congrats on your 2003. You might try the C5 section.
Old Feb 27, 2011 | 01:43 PM
VET4LES's Avatar
VET4LES
Old Feb 27, 2011 | 03:56 PM
dougbfresh's Avatar
dougbfresh
If it's a REAL 50th Anniversary (vs. just an 03'), you might have Magnesium Wheels (a very expensive option when new and super light weight)-you might want to figure that out first.
Old Feb 27, 2011 | 04:37 PM
robert miller's Avatar
robert miller
If you pull them off make sure you keep them....
Old Feb 27, 2011 | 04:57 PM
kenpvette's Avatar
kenpvette
it is a true anniversary with the Magnesium wheels..i thought it would look better with chrome...do u know if the wider wheels will go on an 03
Old Feb 27, 2011 | 07:09 PM
vette.mix's Avatar
vette.mix
Congrats on you 03
Old Feb 27, 2011 | 07:18 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
Old Feb 28, 2011 | 07:48 PM
C5FORFUN2's Avatar
C5FORFUN2
They will work fine, however you may end up with the outer edges of the tire wearing more than the center. Chrome does look the best!!!
Old Feb 28, 2011 | 09:54 PM
If your car is a true Anniversary edition (Anniversary red paint), then it does not have magnesium wheels on it - it has champagne-painted aluminum wheels and center caps. And yes, they are 17x8.5 and 18x9.5 in sizes. Yes, you can put 17x9.5 and 18x10.5 wheels on the car (same size as the Z06). The stock size tires will go on the wider rims, but a more ideal size would be 265/40 fronts and 295/35 rears.
Old Feb 28, 2011 | 09:58 PM
bikgc's Avatar
bikgc
Congrats!!!
Old Feb 28, 2011 | 10:15 PM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
The factory size 17X8.5 front and 18X9.5 rear run flats will not fit the wider rims properly due to their harder composition and inability to stretch and therefore will not keep air when mounted. If the narrower size tires from the stock painted wheels are non run flat replacements then they will have a softer compound and will be able to stretch to fit the wider rims.
Old Mar 2, 2011 | 09:11 PM
Trigger Creep's Avatar
Trigger Creep
I Forget
Congratulations on your AE. Watch out for the bad info amongst all the good stuff here. People genuinely try to help, but bad info keeps circulating too.
Maggies were an option which was NOT available on the 50th Anniversary Edition. They were an (RPO) option on any other '03 and other years (except Z06). The dealer would sell you some and even print you out a nice companion window sticker, but factory they ain't. All 50th AE wheels are painted aluminum.
You can run an inch wider wheel, but you will need a different tire width too. There are plenty of posts you can search for that will have specific info.
To new owner
