Auto Trans "Clunk" Noise
Old Feb 28, 2011 | 10:32 AM
ramontgo's Avatar
ramontgo
Default Auto Trans "Clunk" Noise
I have a 2003 coupe with just 36K miles. I've owned this C5 for almost a year. When shifting my auto trans from drive to reverse I hear a slight "clunk" at the rear driver's side wheel. Lately I've been hearing it when shifting into drive as well. At this point the "clunk" is not very loud, but it sounds like there may be some play in the axel.
Is this normal for a C5? Is there anything I can or should be checking to avoid the condition from getting worse or causing damage?
Thanks!
Bob
Old Feb 28, 2011 | 11:52 AM
Tulsa Vette Guy's Avatar
Tulsa Vette Guy
No this is not normal for a C5, Could be coming the the torque tube also.
Old Feb 28, 2011 | 11:56 AM
ramontgo's Avatar
ramontgo
Thanks! The noise does sound a bit like U joint play in a "tradional" rear wheel drive car.
Old Feb 28, 2011 | 03:55 PM
MY 7T3's Avatar
MY 7T3
Cruising
Default Rear end clunk
Check the axle shift splines. It's a common C5 problem. Check the forum there are good write ups about the fix. Very easy to do.
I did mine 30,000 miles ago, noise has not come back,
Old Feb 28, 2011 | 04:07 PM
02*C5's Avatar
02*C5
Old Feb 28, 2011 | 04:44 PM
MNR's Avatar
MNR
Subscribed.
What is this caused by? Does it hurt anything? Anyone have a DIY, what is this fix you guys are talking about? I have the same issue except mine makes a creaking noise a little bit too.
Old Feb 28, 2011 | 05:08 PM
robert miller's Avatar
robert miller
Hope that it is only this and not your couplers in the TT. azz hole had my car on a dyno ran it up to 200 mph. Then when I went to get it same sound but was coming like just under the shifter. Both of my couplers were shot.
Old Feb 28, 2011 | 05:13 PM
tail_lights's Avatar
tail_lights
At first I was thinking it may be the issue I was having (see thread:http://forums.corvetteforum.com/c5-t...post1576914612) but I do remember mine doing that specific noise (forward to reverse and vice versa) you are referring too long ago and it ended up being the axle nut needing to be tightened and greased.
Old Feb 28, 2011 | 05:58 PM
tail_lights
In your other thread guido7834 answered it. This was the original problem on mine:
http://forums.corvetteforum.com/1563995880-post39.html
Old Mar 1, 2011 | 09:15 AM
ramontgo's Avatar
ramontgo
Hey, thanks for responding to my posting! I love this forum! It gives me a lot of comfort knowing that I can draw from so many others experiences.
Old Mar 1, 2011 | 02:32 PM
tail_lights
You bet!
To Auto Trans "Clunk" Noise
