w
Old Mar 3, 2011 | 01:37 PM
mrmanny55's Avatar
mrmanny55
1st Gear
Default w
help window will not up and the rain is coming in cant get the door panel off c5
Old Mar 3, 2011 | 01:45 PM
Gitusum's Avatar
Gitusum
try tapping on the door just in case ita a bad connection other than that you may want to find some plastic to cover it up til the rain stops
Old Mar 3, 2011 | 01:50 PM
Luv2Fly's Avatar
Luv2Fly
Door panel is 2 screws behind the armrest/handle and some pop out clips around the edge. Use a proper pry tool on the clips or be careful with something else so they do not break. Plastic will be quickest to get it sealed until you are in a nice dry place to fix it.
Old Mar 3, 2011 | 02:41 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Do you hear the relay click? Have you checked the window fuse in the fuse box?
Old Mar 3, 2011 | 02:59 PM
Oh 2 Fun's Avatar
Oh 2 Fun
St. Jude Donor '09, '13, '15
Yeah, fuse is the first place to look if both windows are inoperable. You didn't mention if your other window works.
I've heard that connection can be lost where the wires pass from the body to the door.....inside the rubber boot. Wiggle that around while holding the button.
Please let us know what the fix was. I hate a "hit and run" question about troubleshooting.
Old Mar 3, 2011 | 05:33 PM
TorchRedRocket's Avatar
TorchRedRocket
I was expecting a picture of George Bush.
Old Mar 3, 2011 | 06:42 PM
jrose7004's Avatar
jrose7004
I was too!
Old Mar 3, 2011 | 10:00 PM
Hope you at least got some plastic over the window opening.
Old Mar 4, 2011 | 09:11 AM
Jistari's Avatar
Jistari
drowned ?
Old Mar 4, 2011 | 10:19 AM
dgrant3830's Avatar
dgrant3830
You should be able to swap out the door control modules to verify the operation but be sure to swap them back.
Old Mar 4, 2011 | 06:50 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
Originally Posted by hotwheels57
OK, I'll ask...what does the "w" mean in your thread title?
It means its a window thread
Old Mar 4, 2011 | 07:10 PM
mpride's Avatar
mpride
It's as plain as the 'n' on your 'f'.
To w
