Selective ride
Old Mar 6, 2011 | 11:54 AM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
Default Selective ride
I have the 1st gen C5 selective ride and was wondering about the failure rate of it. Can anyone tell me how many miles they had before it went bad on them? I know it is expensive to fix when it does. I seriously can barely tell any difference between settings they all seem mushy to me. My C4 selective ride was hard as a rock. Does anyone have a explaination on how mine works I know how the magnetic ride control works and that it is a more robust system.
I also do switch it often depending on my drive and my theory is if you use it it will last longer as on the C4 they broke from the shocks freezing from lack of use. Do you guys think switching it often on a C5 will make it last or break?
Old Mar 6, 2011 | 12:06 PM
Cirrus8's Avatar
Cirrus8
I have selective ride control on my '01 and do not know if it is working or not. I do switch it through the modes often because, like you, I believe that electro mechanical devices need to be exercised to keep on working properly. I suppose that the only way to tell is to drive the same course of winding, undulating road several times switching the modes each trip and comparing how you feel the ride has changed. I have plans to do this when I find the correct road.
Old Mar 6, 2011 | 01:34 PM
04 commemorative's Avatar
04 commemorative
St. Jude Donor '17
when driving over an area of road that has a lot of expansion strips....if I switch it from sport to tour I hardly feel the strips at all
Old Mar 6, 2011 | 02:19 PM
y2krtaf's Avatar
y2krtaf
My 01 has it,and it was marginally noticeable until I switched to c6 z51 sway bars.
The bars made a big difference in the ride and handling of the car.I used to just leave mine in sport mode and forget it,but now you can actually tell and feel a difference in the way it rides.
My wife could tell a difference sitting in the passenger seat in the ride from one setting to the other.
(edit)and yes they came from Gene
Old Mar 6, 2011 | 02:20 PM
Double G's Avatar
Double G
Old Mar 6, 2011 | 02:25 PM
NorCalVette Kid's Avatar
NorCalVette Kid
St. Jude Donor '09
I have it on my 98, still works after 73k on the clock.
You can tell it works, on the same bumpy road if I have
it set on Performance it's really a hard ride compared to when I have it on Tour.
Old Mar 6, 2011 | 02:32 PM
johnson-rod's Avatar
johnson-rod
Two things you can do to better utilize your F45 suspension: pull the battery for a few minutes to let it reboot and get softer tires.
My F45 suspension always feels more responsive after a reboot. I can't say if it's real or imagined but the entire car works better. The radio speed volume, the F45 and the dash lights all work better after a hard shutdown. It doesn't cost anything.
The F45 as delivered with GY runflats should be labeled: Hard, Harder and Hardest.
Once I replaced the GY runflats with Michelins the "tour" setting began to make sense. With the GYs "tour" meant "mushy - but still really hard". Now "tour" means - soft ride with control. "Sport" is the same but better. I can actually use "Perf" on smooth roads for a bit of fun.
I use all three settings everyday. Perf for the lower Turnpike, Sport for upper Turnpike and Tour for the exit 14 extension. Who said the daily commute had to be boring?
Oh - I have 85K miles on it. 65K in the last 3 years. No sign of wear.
Old Mar 6, 2011 | 02:54 PM
Carcass's Avatar
Carcass
Same year,same miles.
There's a set of railroad tracks that I go over every day-on"tour",the sunvisors don't rattle,on "perf" they do-it's not night and day,but there IS a difference
Old Mar 6, 2011 | 03:28 PM
nascar57's Avatar
nascar57
I have a 2001 with 58k on it and everything works great. No leaks etc. I can definitely tell the difference between setting. I have a complete extra system just in case anything ever fails.
Old Mar 6, 2011 | 03:59 PM
ShawnFate's Avatar
ShawnFate
Will the z51 sway bars bolt right up ?
Old Mar 6, 2011 | 04:36 PM
y2krtaf's Avatar
y2krtaf
Yes,almost took longer to Jack and support the car than it did to actually change them.
Old Mar 6, 2011 | 09:51 PM
MaximumHP's Avatar
MaximumHP
I have a 2000 with almost 100k on the clock and mine still seem to work, I can tell a difference when switching between settings. I didn't own it with lower mileage so I don't know if they work as good as new, however.
Old Mar 7, 2011 | 01:49 AM
Bluefire's Avatar
Bluefire
I have an 03 Coupe that was equiped with the F55 (MSR). It worked great when new. There was a noticeable difference in the switch settings. Over time it felt like "tour" mode seemed to float a lot. On "Sport" mode, the littlest bumps started to get very jarring.
Two weeks ago (car has 50K on the odometer) I replaced the MSR skocks with Pfadt coilovers. The ride is remarkably better. I set the stiffness (and ride height) I wanted. It is very apparent to me now the the ols shocks were completely worn out. The reason the old ones felt so bad was they had no damping left. The float and the jarring feeling came from zero damping left.
Sorry for the ramble... I just wanted to point out that at 50K mi my MSR shocks were gone.
Old Mar 7, 2011 | 05:15 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
that's the way it seems to me also. i can tell the difference particularly on a less than even roadway.
To Selective ride
