Passanger window gets stuck
Old Mar 7, 2011 | 02:46 PM
Eber's Avatar
Eber
Default Passanger window gets stuck
So the power window motor on my 2000 FRC works fine but the window comes up a little too far on teh passanger side and gets stuck on the metal tab of teh weather stripping causeing it to bow out and not be flush shut...I dont know if i need to adjust teh height on the window but it is very annoying when a pasanger gets in and you have to roll down teh window and then back up for it to close properly
Old Mar 7, 2011 | 03:41 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Lots of posts on this topic.
Advanced Search: Window Adjustment
Here is a link to Search results. You should find a solution here:
http://forums.corvetteforum.com/sear...rchid=22594367
Good luck
