Jack up on a slope
Old Mar 8, 2011 | 12:13 PM
JACKAL0PE's Avatar
JACKAL0PE
Lepus-temperamentalus
Default Jack up on a slope
I want to do some work under my car that will be very messy, so I'd like to do it outside rather than in my garage.
Problem is, I need to get the car up about 2-3 feet in the air (at least one end at a time) and my driveway is very sloped.
Anyone have any ideas how to do that SAFELY? Particularly getting the rear in the air. With the front in the air, I've still got the trans and e-brake holding it in place, but with the rear, all I've got are some chocks that could slide.
Anyone have any ideas?
Old Mar 8, 2011 | 12:27 PM
SSTG's Avatar
SSTG
Cover your Garage floor, seriously. Use cardboard. Don't risk safety.
Old Mar 8, 2011 | 12:28 PM
blackmachdown's Avatar
blackmachdown
i agree!
Old Mar 8, 2011 | 12:32 PM
GOTHAM VETTE's Avatar
GOTHAM VETTE
That's like safely peering into the business end of a gun that's locked, loaded, and just had it's trigger pulled....it's not going to end well.
Do it in your garage.
Old Mar 8, 2011 | 12:41 PM
DaBoz's Avatar
DaBoz
Safety 1st!!
Old Mar 8, 2011 | 12:47 PM
imavettegirl's Avatar
imavettegirl
plastic and cardboard on garage floor.
bag of kitty litter just in case of an accident.
sloped drive = DANGER
Old Mar 8, 2011 | 12:52 PM
jrose7004's Avatar
jrose7004
Or plastic.
Old Mar 8, 2011 | 01:18 PM
itzza427's Avatar
itzza427
A sack of floor dry works wonders after the job as well!! leave it sit over night,,stir it around the next day and leave it sit for a day or two. Usually there is little to no trace of a mess after you sweep it up!! As stated these options beat the heck out of the dangerous driveway options!! Be careful doing it on the level as well,,raising a car that high with out a lift has a bit of a risk factor even under good conditions!!
Old Mar 8, 2011 | 01:56 PM
damilleniumboy's Avatar
damilleniumboy
I had a car "roll" off the jack when I did it in the back garage that is barely sloped. Not a good advise if you ask me.
Old Mar 8, 2011 | 02:52 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
take the safe way. plenty of ways to insure a good complete clean up of your garage floor. not worth taking ANY risk for the sake of a little bit of clean up should it become necessary.
Old Mar 8, 2011 | 07:38 PM
JACKAL0PE's Avatar
JACKAL0PE
I appreciate all the advice, but covering the garage floor isn't an option. There will be a ton of water and it'll run into my basement ruining the sheetrock below. It's either the slope or nothing.
I agree, safety first. That's why I'm asking the question. I have no intention of doing this unless I can ensure that it's done in a safe manner.
Old Mar 8, 2011 | 08:36 PM
BitViper's Avatar
BitViper
I see people doing this all teh time and I awlays stop and wonder WTF are they thinking... It just looks scary.. Yeah.. id put her up as far as I could on standd and have some plastic on teh floor... 30 bucks for a 20x20 piece.. better than being a statistic or a member of teh darwin society
Old Mar 8, 2011 | 08:50 PM
imavettegirl
it would help if we knew what the heck you are going to do?
no one here or any other forum will ASSURE you that doing this on a slope will be safe to do.
Old Mar 8, 2011 | 08:51 PM
TorchRedRocket's Avatar
TorchRedRocket
What about the road? Is there a level enough spot you can do it in the road if you're in a low-traffic subdivision?
Old Mar 8, 2011 | 08:54 PM
Don't do any work on the slope. Do the work in your garage or find another level place to work on your car.
Old Mar 8, 2011 | 09:22 PM
steve8's Avatar
steve8
I can be cheap, and I can be stupid, but really?????
Old Mar 8, 2011 | 09:29 PM
JACKAL0PE's Avatar
JACKAL0PE
No. Wish I could but the road is only slightly less sloped than the driveway.
To Jack up on a slope
JACKAL0PE's Avatar
JACKAL0PE
I want to power-wash underneath it.
Old Mar 8, 2011 | 09:31 PM
momo20's Avatar
momo20
no mess is worth your safty...
Old Mar 8, 2011 | 09:33 PM
imavettegirl
go to a friend's flat driveway.
go to a coin operated car wash.
you have a lot of options.
