[Z06] check engine light, code p1441c(10-pcm)
Old Apr 14, 2002 | 03:33 PM
gto9's Avatar
gto9
Default check engine light, code p1441c(10-pcm)
DOES ANYONE KNOW WHAT THIS MEANS. THE CAR RUNS FINE.I WAS TOLD TO CHECK MY GAS CAP TO SEE IF IT WAS CLICKED AND IT IS.I HAVE A 2002 ZO6 WITH 1800 MILES.I ALSO REFUELED WITH GAS AND RESET THE ENGINE LIGHT AND IT CAME BACK ON. IS THERE A EASY FIX ?
Old Apr 14, 2002 | 05:50 PM
BlackZ06's Avatar
BlackZ06
Default Re: check engine light, code p1441c(10-pcm) (gto9)
According to the Service Manual, a P1441 is:
This DTC tests for undesired intake manifold vacumn flow to the Evaporative Emission (EVAP) system. The PCM seals the EVAP system by commanding the EVAP purge valve OFF or closed, and the EVAP vent valve ON or closed. The PCM monitors the fuel tank pressure (FTP) sensor in order to determine if a vacumn is being drawn on the EVAP system. This DTC will set if the vacumn in the EVAP system is more than a predetermined value in a predetermined time.
Under Diagnostic Aids it states:
The EVAP system tests run when the engine is first started and meets the Conditions For Running The DTC. An intermittent condition could be caused by an improperly installed or damaged EVAP canister purge valve, or by a temporary blockage in the EVAP canister purge valve.
Sounds like one for the dealer to look at ... there is a whole page of diagnostic tests that lead them to replace either the FTP sensor, or the EVAP canister purge valve. It isn't worth your time to mess with if the car is under warranty.
:cheers: Steve
Old Apr 14, 2002 | 06:12 PM
pridnjoy's Avatar
pridnjoy
Cruise-In III Veteran
Default Re: check engine light, code p1441c(10-pcm) (BlackZ06)
Not a biggie...I had same code and it ended up being a bad gasket. Dealer replaced in less than an hour and I was on my way. On a side note, dealer told me driving with this code would not harm anything. Good Luck.
To check engine light, code p1441c(10-pcm)
