Seat cover install
Old Mar 9, 2011 | 01:29 PM
STALION's Avatar
STALION
From: ALL governments are legalized mobsters, so doesn't matter where I live :(
Default Seat cover install
Hey gang, I had a question for those that have installed seat covers. Did you remove the seats to install the covers or did you leave them in the car while installing them? (Ihave the neoprene style covers)
thanks.
Old Mar 9, 2011 | 01:52 PM
(Lucy)'s Avatar
(Lucy)
Account disabled by request Dec 2015
You have to remove the seat!! My wife did my seat covers in about five hours from start to finish. Vette essentials has a How do on there site here it is!! (Not sure about the neoprene seat covers)
http://www.vetteessentials.com/instr...er_change.html
Old Mar 9, 2011 | 02:01 PM
STALION's Avatar
STALION
Well if a girl can do it lol, just kidding. I suspected as much but wasn't sure. The instructions I found were shoddy at best do now I know.
Thanks dragon
Old Mar 9, 2011 | 08:50 PM
rtpassini's Avatar
rtpassini
St. Jude Donor '11-'12
theres been a few topics that suggest you dont need to remove the seats.
depending on what kind you have of course. I highly doubt the neoprene ones need removal.
Recovering one from the ground up, yeah. you would need to.
Old Mar 9, 2011 | 09:38 PM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
If you choose to remove the seats, that would be a good time to perform the rocking seat mod/fix as well!
Old Mar 9, 2011 | 11:17 PM
Patches's Avatar
Patches
I've installed both the Wet Okole's and the CoverCraft neoprene seat covers and both required removal. You could probably get away with just unbolting them to get the bottom straps secured but I just take them out since it's 90% of the way there and much easier to put the covers on out of the car. Plus, I like to vacuum thoroughly the carpet while I have the seats out anyway.
Old Mar 9, 2011 | 11:54 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
It is not hard to remove the seats all you need is a socket set and long extension. I think you can do it without though did it on my C4.
Old Mar 10, 2011 | 07:31 AM
99 vett babycar's Avatar
99 vett babycar
Old Mar 10, 2011 | 08:26 AM
v1 rot8's Avatar
v1 rot8
Default covers
Taking the seats is no big deal, 5 minutes each. It will make the cover install so much easier, could not imagine doing the covers with the seats in the car
Old Mar 10, 2011 | 08:30 AM
STALION's Avatar
STALION
Thank you gentleman...the seats will be coming out...maybe I'll even find a pot of gold underneath my seat, or at least some loose change to cover the cost of coffee!
Old Mar 10, 2011 | 09:02 AM
v1 rot8's Avatar
v1 rot8
You just might, I did find a few coins under mine. Good luck with the seat cover install.
Old Mar 10, 2011 | 09:09 AM
TwinTurboZ51's Avatar
TwinTurboZ51
I re-uphostered my seats with new leather/vinyl. Not sure what neoprene covers entail. Do those go over the old upholstery?
To remove the seats takes 5-10 minutes. That is a good time to clean the carpet under there also.
It took me about 1 hour per seat to re-uphoster them using a hog ring pliers and hog rings.
Entire job took under three hours. You could not remove the old uphostery and install the new without removing the seats.
Old Mar 14, 2011 | 11:29 AM
AUandAG's Avatar
AUandAG
I installed neoprene covers (Coverking) without removing the seats. No problem
Old Mar 14, 2011 | 11:44 AM
Justin01SS's Avatar
Justin01SS
Just recovered mine with new skins yesterday. I would rather take a sharp stick to the eye than try to do that with the seats in the car.
Old Mar 14, 2011 | 03:06 PM
I doubt you'll ever get the covers installed without taking the seats out of the car. Easy to do - just take out the four bolts holding the seat to the floor and then unhook the electrical connections.
A word of advice - be sure to cover your sill area with a blanket or some rags so you don't accidentally scrape them up with the seat rails.
Old Apr 28, 2012 | 04:03 PM
CheezMoe's Avatar
CheezMoe
St. Jude Donor '11-'12-'13,'19-'20
Originally Posted by AUandAG
I installed neoprene covers (Covercraft) without removing the seats. No problem
With whos hands?! Any advice on how to get the over the seat belt and between the seat and the console and fitted properly under the seat would be appreciated!
Old Apr 28, 2012 | 05:04 PM
Double D Mods's Avatar
0Double D Mods
Former Vendor
St. Jude Donor '12-'13
[B][SIZE=4][COLOR=red]
On to the seats! I started by unpacking the new Coverking covers
next I removed the seats
remove caps on front of seats
pull the pins
remove 4 nuts on all for corners
unplug any connectors should you have power seats at this point
pull seats out and place on desired working area
Seat is now out and ready for covers.
slip bottoms on over the stock covers
insert back through seat
connect the to main straps on left and right of seat pulling them nice and tight
there is two more straps to connect on each side. Connect by pulling them tight and hooking onto the seat frame.
pull everything tight and seat bottom is done
next slip top covers onto seats
again pull thought bottom of seat stretch tight and attach to other portion with velcro
teak and adjust the covers at this point pulling them tight
then your ready to drop back into the car
rebolt them down and connect any and all connectors at this point. Reinstall caps
repeat same steps for secodn seat and your done
out some will look like this
While we were at it for install for this customer we aded a hydrocarbon radio bezel and
remounted his Sirius radio so you could close the ash tray lid and not see it when not in use.
To Seat cover install
Old Apr 29, 2012 | 03:12 AM
AUandAG's Avatar
AUandAG
The only tricky part for me was getting the strap under the seat to the rear. I taped the strap to a stick (or was it a yardstick?) and slid it under the seat to the rear, connected it to the rear strap and pulled it tight. Of course, I raised the seat up all the way first. Getting the cover to fit over the seat bottom was not an issue.
Mine are for sale:http://forums.corvetteforum.com/c5-p...lack-gray.html
Old Mar 22, 2014 | 05:39 PM
Joe Cadillac's Avatar
Joe Cadillac
Default C 5 seat cover reeplacement
Anybody have an idea of cost to have them professionaly replaced with real leather??
Old Mar 22, 2014 | 05:47 PM
avigar's Avatar
avigar
A local auto upholstery shop in your area should be able to give you an idea.
