12 inch wide wheels
Old Mar 9, 2011 | 10:06 PM
corvettedaddy11's Avatar
corvettedaddy11
Default 12 inch wide wheels
Any one have any pics of how far a 12 inch wide rim sticks out on stock quarters.......?
Old Mar 9, 2011 | 10:11 PM
jdmvette's Avatar
jdmvette
Night Owl for life
it's the tires moreso than the wheel that will stick out too far.
Old Mar 9, 2011 | 10:15 PM
corvettedaddy11
Bet it will look GAY.........!
Old Mar 9, 2011 | 11:05 PM
jdmvette's Avatar
jdmvette
Night Owl for life
it'll look more like this...
Old Mar 9, 2011 | 11:07 PM
damilleniumboy's Avatar
damilleniumboy
Damn, was that piggie was supperchaged!
Old Mar 10, 2011 | 12:03 AM
corvettedaddy11
Hahahaha i love it ........!:d
Old Mar 10, 2011 | 12:20 AM
Gr8Wht's Avatar
Gr8Wht
CF Veteran
St. Jude Donor '10-'12, '25
12 inches.....Holy shets!
Old Mar 10, 2011 | 12:31 AM
Just Cruise's Avatar
Just Cruise
I got a 11inch on the back with 305s and it looks great. You can do it but would either have to buy the fender kit or the inner wheel well kit. It is actually possible to put a 13Inch rim on a c5.
Old Mar 10, 2011 | 12:36 AM
jacks996's Avatar
jacks996
Jacks996
Cruise-In VIII Veteran
I had 11.5 wide with 305s and it was flush
Old Mar 10, 2011 | 01:14 AM
max'svette's Avatar
max'svette
St. Jude Donor '11
I'm running 11.5 That's as wide as you should go. 12" looks like ****.
Old Mar 10, 2011 | 01:31 AM
zagger's Avatar
zagger
To the guys running 11.5 or 11.0, what offset are you running?
Old Mar 10, 2011 | 02:09 AM
Just Cruise
Im running 9.5 in the front and 11s in the rear. Someone said you can put a 305 on a 11.5 inch rim. Wouldn't the rim stick out. I have 275s on the front but i recommend 265s. The 275s stick out about a quarter inch. I was told to go with 275s don't do it.
Old Mar 10, 2011 | 12:00 PM
JustinStrife's Avatar
JustinStrife
Friend is tubbed like me, but he has 12" widened Z06 wheels and 345 Mickey Thompson drag radials. They sit damn near flush with the wheel well and it looks aggressive as all hell.
Old Mar 10, 2011 | 12:09 PM
corvettedaddy11
Old Mar 10, 2011 | 12:19 PM
JustinStrife
Next time I see him, I'll take pictures and post them.
He's on the forum though. Goes by n20Sage or something like that.
Old Mar 10, 2011 | 12:22 PM
corvettedaddy11
Old Mar 10, 2011 | 12:33 PM
Russ K's Avatar
Russ K
I have 19x11 wheels with a 65mm offset. 305/30/19 tires and they don't stick out or rub.
Russ Kemp
To 12 inch wide wheels
Old Mar 10, 2011 | 01:54 PM
Allthrottleandsomebottle's Avatar
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
Near Flush depending on tire choice with a +74mm offset and tub job
345/35ZR18 Bridgestone Expedia S-01 street tires........(Off the rear of a Jaguar XJ220):
345/30/18 BFG DR:
More wheel/tire pics:
http://temp.corvetteforum.net/c5/30s/index15.shtml
Old Aug 25, 2019 | 03:31 AM
jimbob1128's Avatar
jimbob1128
Cruising
Default My 2cents 11in wheels
On my stock NON ZR1 1994 Corvette. I Currently have 11 inch 50mm Offset on ALL FOUR WHEELS with Zero rubbing or chafing anywhere and can turn the steering wheel 100% for a u turn with NO issues. Tires are 315 Toyo, all four wheels.
The wheel company said for "rear wheels only" but they were mistaken. KONI shocks may help on the vertical bounce, but there is NO wheel rubbing for turns whatsoever. Meaning that GM SHOULD have done this stock.
The handling on off ramps and curves with speed is beyond belief. The wheels stick out 1.5 in and I love them.
Send me your email. I will send you a pic. Jim.
Old Aug 25, 2019 | 01:13 PM
jdmvette's Avatar
jdmvette
Night Owl for life
