Lighting question...
Old May 2, 2011 | 11:43 PM
SCM_Crash's Avatar
SCM_Crash
Originally Posted by gwalker
I just installed the Phillips 9011 and 9012 on Sunday. It took 30 minutes including the modifications to the bulbs. If you have a dremel tool, small file and a small hand you will have no problems.
They are not HID's but are brighter than stock.
Greg
Yeah. The whole process took about 30 minutes for me as well... I used a wire cutter to clip the tabs right. The guys at Finemotoring.com actually marked on the tabs where to cut, even though I had the webpage up and ready for clipping. LOL Made my life that much easier. Going to test the lights in a few minutes.
Old May 3, 2011 | 01:41 AM
mcm95403's Avatar
mcm95403
I've been using Hella H4 6000K xenon bulbs with excellent results. These are in my MR2, but I have similar ones in the C5 and it looks the same.
http://www.marcmedina.com/MR2lighting.html
Old May 3, 2011 | 03:37 PM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
Originally Posted by Mr.Bill
In my ACA's I went with HID lows and Highs, No issues at all, I also have HID in my fogs and that made a big difference. But when talking non hid's I feel that the HIR bulbs are the way to go.
I have HID lows and fogs (4300 temp) and the silverstars in the highs. I was thinking about adding HID highs, however the lows and fogs really light up the road and I primarily use my highs only when I flash to pass. I can only imagine how your ACA HID lows and highs light up the road. The fogs still turn off automatically if you hit the highs correct?
Old May 3, 2011 | 04:25 PM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
Unless you do some sort of mod to change it .... the fogs turn off when the high's turn on.
There is some law I saw that Radioflyer mentioned in another post that having 6x forward facing lights is illegal. (lows/highs/fogs)
I have Silverstar's in my high beam ACA's and they are horrible. It felt like I turned off my forward facing lights completely when I turned on my high beams. I am putting in HID high beams in the next few months. I rarely use my high beams anyway but its nice to have if I need them. I have my low beams set up to stay ON when the high beams turn on. I will have no loss of light when I turn on my high beams.
Toque
