Service your rear...
Old Mar 11, 2011 | 12:04 PM
81c3's Avatar
81c3
Originally Posted by imavettegirl
i can never get all the fluid out of the bottle like that.
a pump is the best and easiest answer and the one i will use.
Actually any hand pump you can buy at your 5 & dime auto parts store will be a sub standard tool... They always leak at the point where the tube fits over the end of the pump nozzle..... and the tubing they supply is waaay too short. The long tube method is the cheapest, cleanest and easiest method, but suit yourself.
Old Mar 11, 2011 | 12:10 PM
BenC5's Avatar
BenC5
Good reminder.
Best are the lube pumps that are made for outboard engine lower units and can be found in WalMart made by Attwood. No leaking.
I have now changed my rear-differential twice in 30,000 miles as I got my car with 32,505 on the clock and now have almost 66,000 miles. I'll probably do it at my next oil change for which I'll probably be due in about 2,000 miles as my DIC is down to 24%.
Old Mar 11, 2011 | 01:20 PM
Jet-Jock's Avatar
Jet-Jock
I'll look at Wally world next time I'm there. I threw the one I got from advanced auto in the garbage.
Sorry Toque I couldn't remember your name when I first typed the post, but I did have the link correct.
Old Mar 11, 2011 | 01:24 PM
BenC5's Avatar
BenC5
I used Royal Purple too and did not put anything else extra in. No problems, no noise, expensive at like $17 or $18 per L/Qt.
Old Mar 11, 2011 | 05:12 PM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
Its all good !
I just hoped it helped you out in doing it yourself and not paying a shop to do it. There not growing money on trees anymore...
Toque
Old Mar 11, 2011 | 05:44 PM
Jet-Jock's Avatar
Jet-Jock
It did, and it inspired me to get it done.
Old Mar 11, 2011 | 06:43 PM
itzza427's Avatar
itzza427
Did it just after I got it with 55k. Have put about 30K since,,so it might be a good idea to change again!! I used RP then,,probably will again. To BenC5,,,with RP,,,you don't need additives,,,it's already in there!!
Old Mar 11, 2011 | 08:34 PM
BenC5's Avatar
BenC5
Yes, itzza, the forum consensus is that RP is good. Even better that it does not require us to put any friction modifier in it. It is just so expensive.
I might go with Mobil1 next time.
Old Mar 12, 2011 | 09:10 AM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
Appreciate those using AMSOIL.
For those interested, here is the product I recommend (and use in my 02 Z06):
AMSOIL Severe Gear Extreme Pressure Synthetic 75w90 (Product Code SVGQT)
Note: This product comes with friction modifier already in it and extra modifier is rarely needed to prevent diff chatter in a C5 (not so for the C6). However, some chose to pick up a tube of the Slip Lock Additive and either keep it handy if diff chatter does occur, or add in a few ounces to ensure there is no diff chatter. I run mine without extra additive.
AMSOIL Slip-Lock Differential Additive (Product Code ADATB)
And the pump mentioned above for the DIYer:
AMSOIL Hand Pump (Product Code G2039)
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Mar 12, 2011 | 09:24 AM
Jet-Jock's Avatar
Jet-Jock
That's a good price on the Amsoil synthetic lubricant compared to discounted prices on AC-Delco lubricant.
Old Mar 12, 2011 | 09:48 AM
C66 Racing's Avatar
C66 Racing
Probably should have mentioned that I'm happy to get forum members dealer wholesale pricing, about 25% below retail, via the AMSOIL Preferred Customer Program. Drop me a PM if interested.
Old Mar 12, 2011 | 06:10 PM
SSTG's Avatar
SSTG
Pm me more info please.
Old Mar 13, 2011 | 08:58 AM
  #33
C66 Racing's Avatar
C66 Racing
Done!
Old Mar 13, 2011 | 09:57 AM
  #34
rws.1's Avatar
rws.1
timely reminder.... thanks
Old Mar 13, 2011 | 10:25 AM
  #35
Jet-Jock's Avatar
Jet-Jock
And it continues to improve as you put a few miles on the fluid change.
Old Mar 14, 2011 | 04:45 PM
  #36
81c3's Avatar
81c3
Did mine today... One of the only things I hadn't done yet. I used Royal Purple. I already had a quart in the cabinet, so I only had to buy one. The fluid looked dark and was probably due at 83k miles! Thanks for the reminder.
Old Mar 14, 2011 | 05:20 PM
  #37
TOPCATHR's Avatar
TOPCATHR
I have used an air compressor and a bottle of lube with a tube thru the cap you put a little air in the botle via a small hole near the top and it works great..... Not too much pressure or boom
Old Mar 15, 2011 | 07:41 AM
  #38
Jet-Jock's Avatar
Jet-Jock
Your welcome, call a public service announcement for your Corvette.
