I had absfixer repair a module a while back and now its acting up. I'm getting c1214. I cleaned grounds and cleaned connections. All is well. Cranked the car up and gave a little rev, that's when code came on.
Absfixer is not returning my call and it is pissing me off. So much for guarentee.
Please help. I went to the ebcm procedure and they mentioned removing to harnesses. I removed the large one by pulling up the gray clip. I didn't see a second. I have an 02 z. Am I suppose to have two harnesses going to the ebcm? Can someone take a pic so I can see where its coming from.
This sucks, please help corvette forum. I don't know of someone getting the fix and have another issue...
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
You have 2 harnesses, One very large one and on the front of that there is a small 2 wire one I believe. I had great service with ABSFIXER, How long ago was the fix done?
If you can't get ahold of them you can check on eBay, There are a ton of guys fixing them for like 40 bucks on up.
Mr.Bill
