[Z06] 02 zo6 help
Old Mar 13, 2011 | 10:38 PM
02bluezo6's Avatar
02bluezo6
Default 02 zo6 help
hey i was wondering what the oil pressure you guys are getting on the gauge on idle and full throttle!? also what temperature your motor usually runs on? Thanks
Old Mar 14, 2011 | 02:49 PM
bud miller's Avatar
bud miller
just another thought...use your DIC to check your guages number and accuracy..my 04 Z runs about 192-205 on temp depending on cruzing or stopped at a light..
35-40 lbs oil press on idle..and up off idle.my DIC confirms those numbers when i look at those guages.
hope dat helps
Old Mar 14, 2011 | 04:03 PM
02bluezo6's Avatar
02bluezo6
Sounds good thanks well I had it pretty open on throttle and oil gauge almost got pinned was little worried wondering if that normal at all and it moves around alot when on the gas is that normal? Thanks alot
Old Mar 14, 2011 | 07:16 PM
bud miller's Avatar
bud miller
yep the oil pressure moves alot.........engine design much different than are old chevy 6..took a lot of revving to move the old needle back then./
To 02 zo6 help
