[Z06] Should I remove the MAF Screen?
Old Apr 15, 2002 | 12:53 AM
CRUZMISL's Avatar
CRUZMISL
Default Should I remove the MAF Screen?
I'm curious if I should remove the MAF screen from my 01 Z? I am currently running a Blackwing and carbon fiber airbridge. Any thoughts?
Thanks,
Joe
Old Apr 15, 2002 | 01:54 AM
SMFCPACFP's Avatar
SMFCPACFP
Cruise-In II Veteran
Default Re: Should I remove the MAF Screen? (CRUZMISL)
Why would you want to do that? :confused:
Old Apr 15, 2002 | 11:41 AM
CJ-Z06's Avatar
CJ-Z06
Yes remove it. The MAF on the 02 is the same as 01 but it has no screen. I have heard 2-3HP with screen removal.
:seeya :seeya
Old Apr 15, 2002 | 11:58 AM
wtknght1's Avatar
wtknght1
Default Re: Should I remove the MAF Screen? (CJ-Z06)
Yeah, this is something the aftermarket tuners have known for quite a while about the MAF. Take the screen out and convert the metal housing (non Z06 only) to the plastic. This makes the air flow better and reduces the amount of heat in the MAF. Cooler air makes more power.
Old Apr 15, 2002 | 12:21 PM
Z06-Goose's Avatar
Z06-Goose
Default Re: Should I remove the MAF Screen? (wtknght1)
It leans the car out a bit.
Old Apr 15, 2002 | 01:42 PM
dbvettez06's Avatar
dbvettez06
Removed mine long ago...The dyno #s on the car before the blower where 356 rwhp and 364 rwtq...I had the Donaldson/TPIS and screen removed...Worked for me :cheers:
Old Apr 17, 2002 | 11:33 AM
AFVETTE's Avatar
AFVETTE
Removed mine from my 99 when I installed the 02 LS6 lid. The combination is fantastic. No issues from my 99, the car just feels much stronger.
Tom
Old Apr 18, 2002 | 04:15 PM
DLSCWBYVT's Avatar
DLSCWBYVT
Had mine removed. It worked for me, no problems.
Go for it! :cheers:
To Should I remove the MAF Screen?
