A/C panel light dim
Old Mar 15, 2011 | 07:31 PM
Jumper11's Avatar
Jumper11
Default A/C panel light dim
All of my lights, radio and dash are controllable with the dimmer switch. The light in the A/C panel does not go very bright and is difficult to see during daylight hours. Is there a secret or a resistor that needs replaced.
Old Mar 15, 2011 | 08:22 PM
whitehooptie's Avatar
whitehooptie
There is a thread here somewhere that shows what to do. Basically you take apart the head unit and on one of the boards, there are some SM caps that need to be resoldered as the heat burns up the contacts.
Old Mar 15, 2011 | 09:04 PM
Jumper11's Avatar
Jumper11
Whats SM?
Old Mar 15, 2011 | 11:28 PM
whitehooptie
Surface Mount
Old Mar 16, 2011 | 01:15 AM
SilverC54me's Avatar
SilverC54me
Here is the link to a thread on how to correct this problem.
http://forums.corvetteforum.com/c5-t...splay-fix.html
Take your time doing this. The circuit board is sensitive.
Gary
To A/C panel light dim
