Pre-Spring Start Procedure?
Old Mar 17, 2011 | 10:03 PM
JMWarren's Avatar
JMWarren
Default Pre-Spring Start Procedure?
Anyone do anything special before turning the key after winter storage?
I was thinking of somehow priming the oiling system....pull a fuel pump relay and crank it for a minute?
Anything else we should consider doing?
Old Mar 17, 2011 | 10:09 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I would check all levels and start it up.
Old Mar 17, 2011 | 10:14 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
Unplug battery tender, disconnect, turn key.
Old Mar 17, 2011 | 10:19 PM
ChromeC5's Avatar
ChromeC5
Don't forget to do a little dance in celebration of the start to a new Corvette season!
Old Mar 18, 2011 | 12:04 AM
spdislife's Avatar
spdislife
There is a technique to turn the engine over without firing it. Hold the throttle all the way down and turn the key. Engine will turn over but will not fire. I usually do that for a count of 3 to 5. Then take your foot off the throttle and start is as you normally would. Whether this is effective, I'm not really sure but I know a number of people who do it and I don't think it will hurt.
Old Mar 18, 2011 | 06:01 AM
ColeTrain'sC5's Avatar
ColeTrain'sC5
Insert key, take a deep breath, pray quick, turn key, and enjoy the warmer weather. I've driven mine twice already but i did so in the snow
Old Mar 18, 2011 | 06:02 AM
baxsom's Avatar
baxsom
I would think that since the most damage is done at start up, you would want it to fire as soon as possible to get the oil pressure up. Just spinning the motor with the starter I dont think would cause enough oil pressure to lube anything so it would be dry metal on dry metal for a longer period.
Old Mar 18, 2011 | 06:19 AM
Cybermind's Avatar
Cybermind
I'm never doing that again! I did that once with a Mazda Miata after a winter storage. Same as most modern fuel injected cars, it wasn't supposed to start with the throttle all the way down. Guess what? It started anyway and instantly revved to almost redline. Talk about a rude awakening after a winter hibernation! It probably did some damage, who knows.
As others have stated and as I did yesterday for the first time after winter storage, simply turn the key and listen to that beautiful V8 coming to life. Let it idle for a couple of minutes and go for a drive, it's almost therapeutic.
Old Mar 18, 2011 | 07:50 AM
steve8's Avatar
steve8
After that idle for a minute, then drive slowly. Check tire pressures/fluids before you start.
Old Mar 18, 2011 | 07:57 AM
That's all I do. After that, back out of garage and enjoy the big smile on your face from getting some behind the wheel time.
Old Mar 18, 2011 | 08:05 AM
laurelboy's Avatar
laurelboy
St. Jude Donor '11
My 02 has also been in the garage for 5 months and is coming out today but I went out and started it up and let it run for 10 minutes every weekend during the winter. Will be nice to rotate the tires and get some driving in this afternoon.
Old Mar 18, 2011 | 09:09 AM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
I hear that........supposed to get up close to 70 here today in Jersey and she'll be coming out of storage.
Old Mar 18, 2011 | 10:51 AM
R Devil's Avatar
R Devil
Yep
Old Mar 18, 2011 | 11:08 AM
JerzeyJoe's Avatar
JerzeyJoe
Started her up yesterday afternoon. Let her run, checked gauges, and tire pressure. Backed her out, shut her off and locked her up. This morning I started her up, backed out and drove to work. What a wonderful drive it was. Can't wait to drive home. Taking the long scenic route.
Old Mar 18, 2011 | 12:06 PM
mmichel's Avatar
mmichel
Default Too excited
It's 70 degrees today here in MA and I just HAD to take the Vette to work - the first ride since storage. I woke up early so I could take off the cover, disconnect the tender, check the oil, clutch, and brake fluids. She started right up and I drove her very slow for the first few miles without the radio so I could listen for any odd sounds. Yes, the sound of that awesome LS1 again! It wasn't until I got on the highway and got a high tire pressure DIC msg that I realized that in my excitement I forgot to adjust my tire pressure before pulling out of the garage (I store the car with the tires loaded to max pressure). What an awesome ride into work today. This is the soonest I've ever taken her out of storage.
In a few weeks, when the weather becomes more consistent around here, I'll need to make an appointment at the dealer to get my windshield replaced (only OEM for my baby). Got nailed by a stone on the passenger side just before I put her away last year.:-(
For those in the northeast - ENJOY THE DAY!
-Mike
Old Mar 18, 2011 | 12:50 PM
baxsom's Avatar
baxsom
Good god, I love being here in FL. This weather is awesome. 50s at night, mid 70s in the day for 2 months now. It did drop down to 30 for a few days back in Jan but that was supposedly a fluke.
Old Mar 18, 2011 | 01:43 PM
Too-Fast's Avatar
Too-Fast
Active Streak: 90 Days
2024 C6 of the Year Winner - Modified
Have to wait at least another 4 weeks, agghhh
To Pre-Spring Start Procedure?
Old Mar 18, 2011 | 03:23 PM
MG RED 99's Avatar
MG RED 99
Don't forget to turn your insurance back on
Old Mar 18, 2011 | 03:34 PM
spdislife's Avatar
spdislife
I suppose the speed at which the engine spins with the starter is slower than that at idle while still pumping some oil...that being said the theory or whatever you want to call it, would assume less damage at the slower cranking speed. Probably need to adress this with some engine guru to see if it's worthwhile.
Old Mar 18, 2011 | 03:35 PM
OBSESHON Mark's Avatar
OBSESHON Mark
Check all the fluid levels, Tire pressures, Un-hook the battery tender, check under the car to make sure there is nothing there to run over,
Do a little sunshine dance, sit down fasten you seat belt, turn the Key & SMILE.
Gotta Love it, Vette driving season is here again.
I've had mine out a couple of times this week, Man it was a long painfull winter.
Those of us that live in areas that receive Snowy cold winters, sure do appreciate & miss how fantastic these Vettes are when we can finally get out and drive them again.
