My dash SPAZZED out!! ?????
Old Mar 18, 2011 | 11:34 AM
TEECEE's Avatar
TEECEE
Default My dash SPAZZED out!! ?????
took my car out for first time in 4 months and everything seemed perfect! THEN, my dash went nuts after about 30 minutes and 15 miles!! ABS warnings, Tire pressure warnings, Low oil pressure warning, Engine power loss warning and others!. i stopped and turned off the car for a minute and then re-started it. haven't seen warnings since and car still is running perfect!! the only thing i see that is odd is the oil pressure is lower than usual. it is around 20 - 22 lbs, and not the usual 38 - 40. All power is there and oil is clean and full. ANY suggestions out there?
Old Mar 18, 2011 | 11:47 AM
Nver2loud's Avatar
Nver2loud
Low battery/bad battery from sitting over the winter? This is the first year in a long time I HAVENT had problems...I just replaced my battery a few weeks ago.
Old Mar 18, 2011 | 11:52 AM
Robomick's Avatar
Robomick
I have had this problem once in a great while also. Whenever I restart the car is goes away.
Old Mar 18, 2011 | 12:58 PM
TEECEE's Avatar
TEECEE
i disconnected the battery. lets hope it is over! and it is reassuring that i am not the only one!! Thanks!
Old Mar 18, 2011 | 01:44 PM
I'd go ahead and get a test done on the battery. When it starts to go bad, a lot of very strange electrical things happen to the car.
To My dash SPAZZED out!! ?????
