Different FOB Problem
Old Mar 19, 2011 | 03:17 PM
Windrider354's Avatar
Windrider354
6th Gear
Default Different FOB Problem
Hi All- After recharging a low battery, my FOB didn't work. Resyncing didn't work either, so I attempted to match the FOB to the transmitter following the manual instructions. I get to the FOB Training display, but then pressing Reset just beeps and the display doesn't change. I can't get to the display where you press the buttons on the FOB. Short of disconnecting and reconnecting the battery - any ideas?
Thanks much.
Old Mar 19, 2011 | 05:06 PM
Windrider354
6th Gear
Default Solved.
I answered my own question. Decided the only possible solution was to disconnect/reconnect the battery. Apparently if the battery gets too low it confuses the computer. Disconnecting/reconnecting reboots the computer. FOB matching/training then works properly.
