Parking Brake Issues
Now I've been trying to get the parking brake shoes re-installed but having no luck.Does anyone have pictures of the way the spring should look like when installed in the parking brake shoes and any tips or directions to get this re-installed? I'm really close to putting it back together with the parking brake shoes and not using the parking brake ever again!!!
Any help would be greatly appreciated!!!
I don't have a picture saved but I've seen one on here recently.(it may have been while I was looking through archives though)
Anyway, try searching using the "title search" feature or if not just hang tight and I'm sure someone will post up that can either explain it or post a pic.
Do like vettegirl says in the mean time and go look behind the e-brake shoes on the passenger side for reference.
Go back into the "search" tech section.
Look for an article (pictured) dated 7/30/2010 by Blue 92
Thread would say"New product-parking brake install tool
only $49.95-corvette forum."
It will show you where every thing is located & an esier way to install
the pesky spring, using simple zip tie's.
Good luck.
PS. A funtional E/brake is an extreme plus!
Good luck.
http://forums.corvetteforum.com/c5-t...y-49-95-a.html
It worked like a charm
