Lowering issue, need help!
Old Mar 23, 2011 | 12:59 PM
CbusFRC's Avatar
CbusFRC
Default Lowering issue, need help!
I am trying to lower my 99 FRC on stock bolts. I got the back lowered just fine, and the front left looks good too. However, the front right sits about half an inch taller. I took the wheel back off and the bolt is turned as far as it will go. The front left bolt shows close to the same amount of threads as the front right which is sitting higher. I drove it for a while to see if it would settle but it didnt. Any thoughts or suggestions?
Old Mar 23, 2011 | 01:16 PM
TorchRedRocket's Avatar
TorchRedRocket
You will find that all C5's have some variance when you compare measurements to the fender lip side to side, perfectly normal. Mine is a good 1/2" higher on the passenger side as well.
Old Mar 23, 2011 | 01:20 PM
TNRAT's Avatar
TNRAT
...Ditto for me...just measured mine last night after installing new wheels....3/8 higher on passenger side (front & back)..
Old Mar 23, 2011 | 01:24 PM
4SFED Z's Avatar
4SFED Z
Mine is perfect all around. takes a while to settle and tweak. measure from facking puck location
Old Mar 23, 2011 | 03:06 PM
myc5toy's Avatar
myc5toy
I looked and looked but still couldn't find that damn "facking puck" on mine?
Mine is a lil uneven too.. About 1/2" higher on the passenger side
Old Mar 23, 2011 | 03:16 PM
mstromquist's Avatar
mstromquist
2015 C5 of the Year Winner
Mine is perfect all around. takes a while to settle and tweak. measure from jacking puck location
Fixed it for ya. This is right I believe. It's the way I did mine. Measure from the frame and not the fender cutouts. Good luck.
Old Mar 23, 2011 | 04:06 PM
CbusFRC's Avatar
CbusFRC
just put the new wheels and tires on.. seems to have evened out a bit. passenger side is a little higher both front and back. O well
To Lowering issue, need help!
