[Z06] Clearing Codes...
Old Apr 15, 2002 | 10:38 PM
Afy's Avatar
Afy
From: Waiting for a flight Trying a Peaceful State of Mind
Cruise-In II Veteran
St. Jude Donor '15
Default Clearing Codes...
How does one do that..
Afy :cheers:
Old Apr 15, 2002 | 10:44 PM
70L46's Avatar
70L46
CF Pit Crew
Cruise-In I Veteran
Almost CI III Veteran
Cruise-In IV Veteran
Default Re: Clearing Codes... (Afy)
Hold down the Options button, and press the Fuel button 4 times. This enters the diagnostics mode. You can then use the Options button to page up through the various systems (PCM, BCM, etc). When you hit the system that has the code(s), press and hold the Reset button to clear. Pressing the E/M button will take you out of Diagnostics mode.
