Popcorn sound at cold start
Old Mar 24, 2011 | 12:35 PM
Miraculix's Avatar
Miraculix
Default Popcorn sound at cold start
My exhaust is making a popping sound at cold start. After a couple of minutes when everything starts to heat up, the popping stops. Does anyone know why?
http://www.facebook.com/v/10150301045625401
Old Mar 24, 2011 | 01:26 PM
Vicistheman's Avatar
Vicistheman
Stops because the popcorn is all popped...Sorry....couldn't resist!!!
It sounds like the condensation in the exhaust might just be burning off. Might want to watch for steam out the pipes. If that stops at the same time the popping does....probably it and no big deal.
If you smell butter...I was right the first time! :~)
Old Mar 25, 2011 | 12:38 PM
Miraculix's Avatar
Miraculix
I feel a sudden urge of going to the cinema everytime I start the car
Old Mar 25, 2011 | 12:55 PM
vette.mix's Avatar
vette.mix
[quote=Vicistheman;1577149830]
quote]
sounds right, that's what our steam pipes do at work. You might want to post in the tech section
Old Mar 25, 2011 | 01:10 PM
hotwheels57's Avatar
hotwheels57
Are there any codes in the DIC? Is the smell of gasoline overwhelming/eye burning?
The popping could be unburned fuel/rich condition in the exhaust system rather than water condensation.
Old Mar 25, 2011 | 05:32 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Sounds right......good tip to watch for steam coming out of the exhaust.. I love popcorn....
Old Mar 25, 2011 | 05:50 PM
garage-ghost's Avatar
garage-ghost
Probably just the pipes warming up.
Old Mar 26, 2011 | 08:20 AM
moserbe's Avatar
moserbe
Piston slap.
Old Mar 26, 2011 | 12:20 PM
Miraculix's Avatar
Miraculix
I don't think so because the car is tuned just right and if that was the problem the popping probably wouldn't stop once the car started to warm up
Old Mar 26, 2011 | 12:22 PM
Miraculix's Avatar
Miraculix
Don't know if this works but I'll give it a shot
Here's the sound at cold start
Note that the popping has stopped in the last section of the video when the car has warmed up
Old Mar 26, 2011 | 01:49 PM
MG RED 99's Avatar
MG RED 99
Sounds a little excessive and more than just condensation. Also if it was tuned just right the popping might not happen at all, just a suggestion. Looks like you have quite a bit of work going on there, good luck.
Old Mar 26, 2011 | 02:03 PM
Big Duk's Avatar
Big Duk
rich condition
Yello95's Avatar
Yello95
St. Jude Donor '11
Did you look at the DIC? It says "service active handling" and "low washer fluid"...add some washer fluid...problem solved?
Old Mar 26, 2011 | 02:16 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
I totally have to agree with this - it looks as if you are doing a lot of work on the Vette and with the exhaust mufflers OFF there is absolutely "NO" back pressure on the Vette thus the popping!
Are your Catalytic Converters removed too?
Because that would definetely make a huge difference along with the mufflers being removed!!!!
Thanks,Matt
Old Mar 26, 2011 | 02:21 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I am no expert, But it sounds like a cold mis fire to me.
Old Mar 26, 2011 | 02:26 PM
Miraculix's Avatar
Miraculix
The car sounded exactly the same even before I cut the mufflers off
If I would have a guess it would be the cats, I don't know what brand they are but they're supposed to be "race" according to the previous owner
Old Mar 26, 2011 | 02:30 PM
Miraculix's Avatar
Miraculix
No codes and not running rich, I know the smell and eye burn because it was running rich when the lambdas were attached incorrectly and this is not the case now
This is not really a problem for me since the popping goes away after a couple of minutes, I'm just currious as to what causes this. And, well yea it would be great to know whether the engine is going to blow up anytime soon or something but as long as the popping only occurs when the car is cold, I'm not to worried, only curious
Old Mar 26, 2011 | 06:43 PM
Armycop's Avatar
Armycop
what engine/exhaust/intake modifications have been done to the car? It would help us 'armchair' diagnosticians to pinpoint, or at least ballpark, your problems.
To Popcorn sound at cold start
