I pod connections
Old Mar 24, 2011 | 04:43 PM
1960mark's Avatar
1960mark
Default I pod connections
Was wondering which interface to buy the Icar or peripheral for my C5? I found the peripheral to be cheaper. Any input would be greatly appreciated. Thanks
Old Mar 24, 2011 | 04:46 PM
Bad97ta's Avatar
Bad97ta
pxdp. works perfect and has either connections for the cd changer or back of the radio.
Old Mar 24, 2011 | 08:00 PM
str8fan's Avatar
str8fan
Call Dennis at double d I just purchased one and it works awesome , Took about 45 min with interuptions I drilled a hole in the ashtray just big enough for cable to fit and it can all be put away and is totally stealth.
Old Mar 24, 2011 | 08:08 PM
Rob04C5LM's Avatar
Rob04C5LM
I've got the iCar, it was REALLY easy to install and the signal quality is good. The only issue I have is that it hesitates a second or two after you press the "next" button on the head-unit before it switches tracks.
Old Mar 24, 2011 | 08:57 PM
1960mark's Avatar
1960mark
I wonder if that is something the peripheral does also?
Old Mar 24, 2011 | 09:00 PM
Gr8Wht's Avatar
Gr8Wht
CF Veteran
St. Jude Donor '10-'12, '25
What is an iCar?
Old Mar 24, 2011 | 10:31 PM
Rob04C5LM's Avatar
Rob04C5LM
Originally Posted by Gr8Wht
What is an iCar?
http://www.icarkits.com/ iCar is just a box that translates your iPod signal into the headunit through the CD changer port.
Old Mar 25, 2011 | 10:02 AM
JaxC5's Avatar
JaxC5
What is an iCar?
<---- I think it's one of these....
Old Mar 26, 2011 | 08:04 AM
1960mark's Avatar
1960mark
Thanks for the input I ordered the peripheral should be nice to have my tunes in the vette!
Old Mar 26, 2011 | 02:42 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
talk to dennis at dbldmods
Old Mar 26, 2011 | 05:41 PM
1960mark's Avatar
1960mark
Thanks, thats were I ordered from should have it next week.
To I pod connections
