Should I use a car cover?
Garage is clean and dry with a well fitting roller door but no a/c.
Cheers, Andy
The cover I use is called the "Superweave", not inexpensive, but it protects the car against all contaminants, UV resistant and water resistant. I chose this particular cover because it folds down into a very compact bundle which can be carried in the Z16 trunk cubby hole. It's a thin high tech material resembling a nylon material. It can also be washed/dried in typical home washer/dryer units, unlike the thicker flannel products I used in the past. I think most people with the typical heavier/thicker covers do not bother with cleaning them regularly. I know I didn't. The downside to the heavier covers is they're awkward for a single person to R&R them.
Any cover should be removed/folded in the recommended manner so that the clean interior of the cover never comes in contact with the contaminated exterior of the cover. The clean interior of the cover should never come in contact with the floor/ground.
QUOTE:
"Providing the premium in outdoor, all-weather storage protection; Superweave is our most UV resistant, water resistant and weather resistant cover. The versatile Superweave material features unsurpassed moisture, dust and pollutant protection. The encapsulation technology goes INSIDE the fabric, around the fibers, resulting in a silky smooth finish that glides over fine paint finishes. Superweave is also dust-proof so it will keep your vehicle clean whether it is stored indoors or out. It still remains exceptionally breathable, allowing moisture, condensation and heat to easily escape from under the cover. When rain hits the cover it simply runs right off and any moisture left on the cover will usually dry in about 10 minutes. Its unique lightweight design also enables it to fold up to 1/3 the size of your typical outdoor car cover (about the size of a sweatshirt or jacket), but does not take away from its ability to protect your automobile's finish. The material is also easy to care for because it is the only fabric that is washer and dryer safe. 4-year limited warranty. The Superweave can be ordered in one or two-tone color combinations. Available in Black, Bright Blue, Grey, Sky Blue, Green, Red, Taupe and Yellow. Motorcycle covers are also available in the Superweave material; in Black, Grey and Taupe - single color designs only. Made in the U.S.A."
Zero issues so far.
This works for me.
Bob G.
and clean, no issues!! I have two cats who just love to sit on the car.
I use a California duster before putting on the cover.
For ..........7
Against ....6
My cover came with the car and has never been used. It is Stormshield and was supplied by the dealer and is GM approved.
I have just done an exchange roof for nearly $700 and it looks so good I want to protect it from any contaminant as I assume Lexan is more easily damaged than glass.
Cheers, Andy
