right side power window dead
Old Mar 27, 2011 | 12:25 PM
87gtNOS's Avatar
87gtNOS
Default right side power window dead
Hey guys....car is out of storage and in my garage at home, and I can't get the right side power window to go down. I just here a faint click when I press the button...tried both buttons.
Is there a fuse or relay? I looked under the hood and in the passenger kick panel and cannot find a PWR WDW fuse or relay...
Any ideas?
Old Mar 27, 2011 | 12:41 PM
k0ts's Avatar
k0ts
There is a fair amount of discussion on this subject... If you search you'll find some... There are several things that might help... It's a common problem with the C5... Good luck..
And I'd post/search in the "tech" forum..
Old Mar 27, 2011 | 12:51 PM
billmiller8's Avatar
billmiller8
Any ideas?
I just bought a 1997 vette and mine does the same thing clicks but will not go down, if you find any answers please let me know. Thanks and good luck. I will try and research this myself and let you know if I find anything. In the mean time if someone reads this and can help us out please do so. I was told to hold the button down at the same time I slam the door but this did not work.
Old Mar 27, 2011 | 02:40 PM
frankb's Avatar
frankb
I had the same and it was eathier fuse21 or 23 that I replaced
wit2pz's Avatar
wit2pz
Guys, don't panic. This is pretty common and I was able to find a simple fix on this forum. I remember having to remove a few screws from the door and a small panel which exposed the bottom of the window motor. Once that is exposed, stick a screwdriver inside and give it a few light whacks with another tool, like a wrench or pliers or hammer. It's worked on 2 separate occasions for me and the motor hasn't failed again in over 3 years.
Do a forum search as well as a google search. You'll find the thread and the simple fix.
Old Mar 27, 2011 | 02:53 PM
87gtNOS's Avatar
87gtNOS
LOL! Fixed it!
Sat in passenger seat and with my right fist, hit the door panel next to the speaker while pressing the button and it started to work!!
Thanks guys!
Old Mar 27, 2011 | 03:05 PM
wit2pz's Avatar
wit2pz
Guys, try this for future reference.
http://forums.corvetteforum.com/c5-g...-easy-fix.html
Old Jun 5, 2011 | 08:49 PM
tixin's Avatar
tixin
Just fixed my window by holding the switch down and slam the door shut. It worked! Thanks!
Old Jun 19, 2011 | 03:29 PM
petercln's Avatar
petercln
Used the above method to fix my brother in laws pass window. He just doesnt drive his 02z enought.
Old Jun 19, 2011 | 04:03 PM
wascapsfan's Avatar
wascapsfan
The fix is easy and somewhat permanent.
Open the door and pull the accordion. You will find a male and female plug together in there. What the problem is....the pins occasionally work there way back out of the female so the best way to fix this is to have one person reach in from between the doors and another reach in from under the dash through the entry hole behind the kick panel ans shove the two plugs back together, but shove them together by the wires just behind each plastic plug and the one that slipped out will relock.
Problem solved!!!
To right side power window dead
