Radio replacement
Also, some people say that they have a double din in their car. What happens to the HVAC control unit ??
Any assistance is appreciated.
As for the HVAC question, I've seen it done two ways; one they just swap the radio and HVAC so that when the screen flips up, it doesn't block the A/C vent at the top.
In the second case, they're using a unit with a permanent screen (rather than a flip up). They swap the two and then cut out the ashtray section at the bottom.
Here's a link to everything you ever want to know, probably MORE than you want to know. Look at post #3 for info on modifying the console bezel.
http://forums.corvetteforum.com/audi...audio-faq.html
Dennis can steer you in the right direction.
Jeff
IMG]http://i992.photobucket.com/albums/af44/jol48/vette%20pics/dashwithstereo.jpg[/IMG]
1) Factory OEM bezel is removed
2) HVAC unit and OEM Bose head unit is removed
3) The frame that holds the radio will need to be modified. In particular, there is a shelf that supports OEM factory radio. It will need to be removed and then "rolled over". This process involves tedious drilling out of rivets that supports the shelf. There are metal tabs in the rear that will also have to be removed or folded back. A plastic wire support in the rear will need to be snipped out. These changes are done so the head unit will slide all the way back.
4) With the above changes, you can slide down HVAC control.
5) The final part is re-alligning the double din head unit and the HVAC so the bezel properly fits. This part can be very tricky.
There are several options for hookup which the OP didn't ask about. You could go with OEM integration box to keep factory speakers or go all out with aftermarket power amps, sub, speakers.
As others pointed, talk to Dennis at Double Din Mods. He's the authority.
great to deal with and always has time to help the customer after the sale
