auto dimming mirrors
Old Mar 30, 2011 | 12:32 PM
harold50's Avatar
harold50
Default auto dimming mirrors
I am looking for a complete white led module to change out the amber and
blue factory style on auto dimming rear view mirror ?
2001 vert
Old Mar 30, 2011 | 01:59 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
2001 vert
You might get a hold of tstar a forum member, I believe he sell the replacement board with the white led's in them for the auto dimming mirror, I did mine and it worked great, The factor colors really sucked...lol
Mr.Bill
Old Mar 30, 2011 | 02:51 PM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
I believe JW Motoring (forum vendor) also supplies these LEDs.
Old Apr 5, 2011 | 11:21 AM
harold50's Avatar
harold50
A lot of work and wiring and this is the finished project.
It is 3 times brighter than the factory led and has a bright white light---not
that sick yellow tint! cost $10.10
Old Apr 5, 2011 | 11:50 AM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
I did mine with 5mm LED White 20000 mcd bulbs. Had to take the boards out un solder the bulbs and replace them. If you do it make sure you get the polarity right on the bulbs. Look at the "filaments"( I know they are not called that) and put the new ones in the same way.
Old Apr 5, 2011 | 11:52 AM
MSG C5's Avatar
MSG C5
So, I take this mod is not simply plug and play and requires cutting, soldering, etc.?
Old Apr 5, 2011 | 12:16 PM
Appears that way. Too bad as it would make it so much easier.
Old Apr 5, 2011 | 01:04 PM
Redeasysport
Bill says Tstar has the boards those should be plug and play. Pop the lens pull and unplug board replace and good to go.
To auto dimming mirrors
