c5 corvette coding
Old Apr 1, 2011 | 08:17 PM
Mikejan's Avatar
Mikejan
Default c5 corvette coding
my corvette airbag light is on . I called technician he checked and did something all lights was off but after 2 3 cycle airbag lights comes on again . he said my scan says problem on 2 code 1- B1001 second one is 1630 code the problem is in cluster and your security system . I took off the cluster about 2 weeks ego and put the aluminium bezel on like c6 model and put back the cluster one by one by instruction of people of furm that helped me. so is there anyone to help me out on problems of those code that i mention or probably know what is going on on my car system. thanks
Old Apr 1, 2011 | 09:08 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
It sounds like you might have to remove the cluster again and check all connections - there is also the Airbag Connection to the steering wheel that you might of disturbed - again you will need to go through the procedure again and check everything you come into contact with -
Here is a list of codes for the PCM and what they mean as well as how to access them from the DIC panel:
http://www.stengel.net/diccodes.htm
Make sure you re-run the codes and get the "CORRECT" code like "P" or "B" etc. - you will need to check this and let us know
Thanks,Matt
