FYI : spark plug starter tool - ceramic headers
Old Apr 3, 2011 | 03:49 PM
Tangl's Avatar
Tangl
Default FYI : spark plug starter tool - ceramic headers
Just an FYI - if you pull the wire and clip out of an old plug wire, you can use the boot as an excellent tool for starting plugs without scratching or dinging your coated headers. Once started then it is easy to get the socket on it without a hassle and no scratching of your headers.
Old Apr 3, 2011 | 04:44 PM
dougbfresh's Avatar
dougbfresh
I've used rubber hose for years, great for deep wells where you can see the plug.
Old Apr 3, 2011 | 06:24 PM
Tangl's Avatar
Tangl
rubber hose was always good too, but always had to find a straight piece. The boot is tailor made. If you need extra length a 1/4 in piece of dowel does the trick.
Old Apr 3, 2011 | 06:35 PM
vette.mix's Avatar
vette.mix
Me too ^^, thanks for the tip, I will try that next time
Old Apr 3, 2011 | 10:55 PM
Good tip. I too have used an old piece of rubber hose to do mine.
To FYI : spark plug starter tool - ceramic headers
