Panic attack while getting gas
Old Apr 5, 2011 | 06:15 PM
TEXASCOUPE's Avatar
TEXASCOUPE
Default Panic attack while getting gas
May not seem like much now but this was the first time I stopped for gas after tearing apart the console to repair my dim lights on the HVAC; which went very well by the way. Anyway I pulled in the station this morning since I was on reserve. Pushed the gas door switch and nothing happened. Ok, I'm almost out of gas; can't open the gas door; don't have enough to get to work or go home. Talk about feeling helpless! I knew there was a manual cable to open the door but didn't know where it was. After fumbling around in the hatch I finally found it and got it open. Tore into it just now and found the plug had come off. All is well now!
Old Apr 5, 2011 | 06:16 PM
04 commemorative's Avatar
04 commemorative
St. Jude Donor '17
Breathe
Old Apr 5, 2011 | 06:18 PM
TEXASCOUPE's Avatar
TEXASCOUPE
Originally Posted by 04 commemorative
Breathe
I am now.
Old Apr 5, 2011 | 06:19 PM
Gitusum's Avatar
Gitusum
i have done that before !!!! its funny now but when its happening yourrear puckers up
Old Apr 5, 2011 | 06:23 PM
TEXASCOUPE's Avatar
TEXASCOUPE
Got that right!
Old Apr 5, 2011 | 06:25 PM
rdwiv's Avatar
rdwiv
Potential problem noted - thanks!
Old Apr 5, 2011 | 06:32 PM
mcgilles's Avatar
mcgilles
a lousy connection anyway! I don't understand why they didn't design the connector so it would plug straight in rather than going in sideways. that's got to make assembly more difficult. one of these days I'm going to silicone the connector together so it won't come apart anymore and add my own small disconnect where its easy to get to. plugging that thing back in is such a pain! mine's been unplugged for several weeks now, I hooked it up to one of my alarm remote's buttons and found that I never use the stock button anymore. I never remember to hit it and always had to crawl back into the car. but that's no longer a problem!
Old Apr 5, 2011 | 06:37 PM
TEXASCOUPE's Avatar
TEXASCOUPE
Just what I was thinking, about the sideways mount. Seemed like it put a lot of strain on the plug during re-assembly. Didn't know about the remote thing. How did you do it?
Old Apr 5, 2011 | 06:39 PM
csexton's Avatar
csexton
Glad you found the problem
Chuck
hotwheels57's Avatar
hotwheels57
The button periodically won't work on mine, either. I've made numerous minute latch adjustments, lubed it and cussed it. I had it so sensitive at one point, just closing my drivers door would open the gas door.
So I made a point of learning where the secondary release mechanism was. And I intentionally try to look "cool" if I have to open the trunk to access it. I may be in the minority, but since this was my first Corvette, I made a point to read the manual to learn where it was.
I also never allow my tank to get below 1/4 just to avoid running out of gas.
Old Apr 5, 2011 | 06:46 PM
TEXASCOUPE's Avatar
TEXASCOUPE
You're right about not going below 1/4 tank. Don't usually let that happen. Love that about trying to look "cool" while opening the door!
Old Apr 5, 2011 | 07:03 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Been there done that........
Old Apr 5, 2011 | 07:17 PM
TorchRedRocket's Avatar
TorchRedRocket
More incentive to not run your tank too low.
Old Apr 5, 2011 | 07:25 PM
Chicago1's Avatar
Chicago1
Pics of wife? Oh wait wrong section...
Old Apr 5, 2011 | 07:34 PM
Rob04C5LM's Avatar
Rob04C5LM
Thank you, just learned where the manual release is.
Old Apr 5, 2011 | 07:42 PM
0331MARINE's Avatar
0331MARINE
From: You know your drunk when you swerve to miss the tree then you realize its your air freshener! Covington Ga
I've done it. The wife and I were going on a day trip after I put my short shifter in and I didnt plug it back up. Good thing we stopped before we got to far down the road.
Old Apr 5, 2011 | 07:57 PM
mcgilles's Avatar
mcgilles
its an aftermarket security system with aux outputs. I used one of them for the fuel door. the two wires you see going to that connector, one is hot at all times, the other when given 12+ energizes the solenoid that opens the fuel door. I used one of my alarm's aux outputs to energize a normally open relay and tapped it into the two wires. when I push the lock and unlock buttons at the same time, it "pushes" the fuel door release button for about 1 second.
To Panic attack while getting gas
Old Apr 5, 2011 | 08:00 PM
Stan MI's Avatar
Stan MI
I thought the OP was going to be talking about gas prices.
I was close.
Old Apr 5, 2011 | 08:03 PM
TEXASCOUPE's Avatar
TEXASCOUPE
I like that!
Old Apr 5, 2011 | 08:43 PM
mcgilles's Avatar
mcgilles
I like that!
thanks! its come in very handy! once I installed it I suddenly stopped using the factory button, what a surprise. its been disconnected for a while because I just didn't want to mess with plugging it back in, its a tight fit! I haven't missed it.
a nice thing about it is the alarm outputs a ground for its signal, so I used the +12 wire right there at the door release harness to get power from, it made the install very easy! I used a single "ice cube" relay and double sided taped it to the right of the shifter under the radio trim bezel.
one time when I have it apart I'm still going to add another connector that's easier to get to. been meaning to for a while, but with the remote there's not much motivation to go do it.
