Help - all gauges not working, reduced engine power etc.
Old Apr 6, 2011 | 07:37 PM
malligood55's Avatar
malligood55
Default Help - all gauges not working, reduced engine power etc.
Today I had a shop install a new oil sending unit and on the drive home check gauges started flashing, dic says reduced engine power, check tire pressure, low fuel, all guages set to zero. I did go through a touchless car wash could something have gotten wet. How do I trouble shoot?
Old Apr 6, 2011 | 07:45 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
I would disconnect and then reconnect the battery. Also, go into the DIC and bring up the codes and post here. We can give you better info with the codes.
Old Apr 6, 2011 | 07:53 PM
Oldvetter's Avatar
Oldvetter
Check the codes BEFORE disconnecting the battery ! Or else you may loose the codes.
Old Apr 6, 2011 | 08:25 PM
malligood55
Codes
10-PCM I forgot to put this one down
40-BCM B2721 U1016 U1096
58-SDM B1001 U1016 U1096
60-IPC U1016 U1088 U1176 U1160
28-TCS U1016
99-HVAC U1096 U1160
I reset the codes and went for a 20 minute drive , no codes yet. I have not disconnected the battery, should I do that?
Thanks,
Mack
Old Apr 6, 2011 | 09:17 PM
malligood55
Originally Posted by malligood55
Codes
28-TCS U1016
99-HVAC U1096 U1160
Thanks,
Mack
ttt
Old Apr 6, 2011 | 09:28 PM
robert miller's Avatar
robert miller
Default ttt
Do a search in here on codes. There is one post one guy put up all most ever code in the book and what it goes to..
Old Apr 6, 2011 | 09:35 PM
malligood55
Thanks Robert I did that and it appears most of them are communication issues with the PCM. Hopefully something got wet at the car wash as all seems fine now.
Old Apr 6, 2011 | 09:45 PM
Qwik01's Avatar
Qwik01
Mine did this months back. I read the how-to on the liquid electric tape for the bare wire inside the door harness. It just now returned yesterday. Except in my case the radio cuts off and windows stop working. Traction control shuts off and the only gauges that work are battery volts, speed, and rpm. When I turn off the car and back on its back to normal until next time.
Old Apr 6, 2011 | 10:19 PM
malligood55
It is rather alarming when it happens. Thankful the wifey wasn't driving she would have freaked.
Old May 12, 2011 | 06:03 PM
touring2's Avatar
touring2
Default liquid tape on "bare" harness wire
just did a test drive. time will tell, but it is at least as fixed as good as : when I shook the rubber boot like you grab a chicken by the neck!
Old Nov 23, 2017 | 12:07 AM
emclass's Avatar
emclass
Thanks guys, this solved my issue as well. Now I have something to be thankful for.
Old Nov 23, 2017 | 01:14 AM
To Help - all gauges not working, reduced engine power etc.
