OK guys what is the tallest or shortest tire that will be effective on the drag strip? I am looking at getting some Mickey Thompsons but I'm not sure on what size. Car is 390whp and has stock 3.42 gears.
Options I'm entertaining.
305/45 18 29in tall, Most Sidewall available in an 18, as far as I see. Should hook good.
305/35 18 26.39in tall, Would probably help reduce bog
I will be running stock 18X10.5 speedlines at the track and I could not do a smaller diameter wheel even if I wanted to due to my brakes.
