help plz iat sensor does not work
Old Apr 10, 2011 | 08:36 PM
Goole Boy's Avatar
Goole Boy
Navigator
Default help plz iat sensor does not work
i have a 2000 corvette c5 my iat sensor is not gettin power is there a way to by pass the iat
Old Apr 10, 2011 | 09:04 PM
PEERPSI's Avatar
PEERPSI
I don't think bypassing it is a good idea. Using a volt/ohm meter measure the voltage between the two pins at the connector for the IAT. It should be 5 volts. Measure the resistance of the sensor It should not be infinite or show as an open circuit.
