Gas tank leakage
Old Apr 10, 2011 | 09:39 PM
laker-yel-c5's Avatar
laker-yel-c5
2nd Gear
Default Gas tank leakage
I just purchased a '01 C5 a few months back. Recently, I noticed a gas smell in the interior. I filled the car and went for a drive and on my way home my gauges said the tank was empty. I could hear a grinding noise. What's going on?
Old Apr 10, 2011 | 09:45 PM
Jet-Jock's Avatar
Jet-Jock
These tanks have a vent valve that can leak fumes. Also, add Techron to your gas and/or use gas with Techron in it to solve the faulty gage problem. Check the stickies out at the top of C5 General for weights, measure... etc. You'll see a picture of the sender and why it misbehaves.
Old Apr 10, 2011 | 11:03 PM
Good advice. The Techron will help remove sulfur deposits that may have formed on your sending unit, thus causing the gauge to read in error.
Old Apr 10, 2011 | 11:29 PM
jrose7004's Avatar
jrose7004
I wonder what the "grinding" sound is?
Old Apr 10, 2011 | 11:46 PM
Jet-Jock's Avatar
Jet-Jock
Just a typical noisy fuel pump. They each have their own behavior seems like. Mine likes to kick in after an hour or so of hwy driving. In town nary a peep.
Old Apr 11, 2011 | 11:13 AM
kedvesh's Avatar
kedvesh
Word of caution.
Yes; the smell may be caused by a bad or improperly installed fuel filter, bad sealing gas cap, etc.
HOWEVER...
A number of C5 model years (don't remember year or years) reportedly had issues with gas tank delamination and/or cross-over tube issues, causing leaks, thus the smell. (I think there are a few CF threads on this.)
WRT my 2002, it was the gas tank that was causing my smell, but it was due to a knicked tank from when my welded-in roll bars were installed. Not cheap to fix (upper hundred dollars for the mxs dept at my local dealership to drop the tanks and repair pin-sized hole).
Had the gas gauge issue as well (i.e., gage suddenly dropping to zero or remaining "stuck"). The techron fix didn't solve my issues and both my gas tank sending units were ultimately replaced under warranty (back when my warranty was still in effect). At the time, I was told it all had to do with sulfur in various brands of fuels attacking the units and causing the issues. No problems since replacement.
Good luck on the grinding sound.
To Gas tank leakage
