Difference in 2000 to 2002 corvettes
Old Apr 12, 2011 | 08:36 PM
Loverofcorvettes's Avatar
Loverofcorvettes
Default Difference in 2000 to 2002 corvettes
Is there any performance, or suspension differences between the base model 2000 corvette and the 2002 corvette? Thanks.
Old Apr 12, 2011 | 08:49 PM
Gitusum's Avatar
Gitusum
about 2 years give or take a few days
Old Apr 12, 2011 | 08:50 PM
Jet-Jock's Avatar
Jet-Jock
* Millennium Yellow available
* "Thin Spoke" versus "wagon wheel" design wheels become standard.
* Pup cats added to all models for LEV emissions requirements (5hp loss relative to 97-99)
* Steel swaybar endlinks instead of plastic on Z51 equipped cars
* Z51 swaybar diameters grow (25.4/21.7 to 28.6/21.7 to 28.6/23.6 (note: new rear same as Z06)
* No keyhole on passenger side doorhandle
* Passenger airbag 'off' switch added to console (light by TC/AH button)
2001
* Return to 28# injectors for all models.
* Second Generation Active Handling
* Nassau Blue discontinued
* Alternator 'clutch' pulley added on A4 cars
* New soundproofing + foam in all cars
* Smaller keyfob
* Electrochromic dimming rearview and driver's mirrors
* Lighter AGM battery
* Thickness + Material in Convertible change
* Chrome exhaust tips for coupe + Convertible
* 85MM MAF with integral temp sensor (versus 74mm with separate plug for IAT)
* LS1 cam profile changed to: .500/0.500, 198/208 on 115.5LSA (From: 0.472/0.479, 202/210 on 117)
* All Corvettes now have the LS6 intake manifold
* All Corvettes now have the LS6 engine block (windage passages in block), which includes a beefier oil pump.
* LS1 changes result in new output of 350 HP @ 5200 RPM and 375 Ft Lbs of torque @ 4400 RPM (MN6)
* Hardtop/FRC discontinued
* Stronger synchros in all transmissions
* Exhaust manifolds revised (5hp regained) - thin wall cast replacing SS manifolds
* Metal valvestem caps (late year)
* Torque Tube changed from metal-matrix composite to aluminum alloy 6061, increased in diameter from 55 to 63 mm.
* Driveshaft couplings have also been upgraded on manual-equipped models for additional strength and durability
* Introduction of the Z06, which has as differences:
* Hardtop body style
* Rear brake ducting
* Screened inlets on front fascia, without foglights
* F1 Supercar tires 265-17 front, 295-18 rear, on 17x9.5 and 18x10.5 (one inch wider, respectively
* New LS6 top-end with new style head design (10.5:1 compression, 64cc chamber), LS6 cam (0.525/0.525, 204/211 on 116) - 385hp
* M12 transmission with shorter gearing (1-2-3 analagous to MN6 with 3.90 rear diff
* Titanium exhaust system
* Lightweight windshield
* New, stronger clutch with redesigned master + slave cylinder
* Stronger rear differential (shotpeened ring gear)
* Red brake calipers (otherwise identical)
* Transmission overtemp warning light on DIC
* 6500 redline gauges with special checkering + Z06 font
* Redesigned PCV system to help combat oil burning
* Red LS6 Fuel Rail Covers (FRC's)
* FE4 Z06 suspension - uprated springs, bars (30mm/23.6mm), shocks (note front spring and rear bar same as Z51)
2002
* Z06 Changes:
* Z06 LS6 cam changed to: 0.551/0.547, 204/218 on 117.5
* Less restrictive intake airbox lid
* Descreened MAF
* Removal of pup-cats (total with changes = 405hp)
* Z06 shocks revised with less rebound for better launching
* Z06 brake pads revised for better stopping (generate more dust)
* Lighter, sodium filled valves w/ stronger valve springs
* Higher tension rings installed to prevent oil burning problems
* Slight piston redesign *
* Clutch strength upgraded.
* HUD available on Z06 (not avail '01 model year)
* Wheel supplier changed to Speedline, moved from forged to cast. Weight nearly identical
* Electron Blue color offered
* Steel endlinks changed to aluminum
Old Apr 12, 2011 | 08:53 PM
Phanni's Avatar
Phanni
To be brief, 5 HP, and a few nuances that can be expensive,
Key fobs, EBCM, TPMS, all are higher replacement cost on 2000.
Old Apr 12, 2011 | 11:04 PM
2KFRC5's Avatar
2KFRC5
http://forums.corvetteforum.com/c5-g...-corvette.html
Old Apr 12, 2011 | 11:25 PM
Rob04C5LM's Avatar
Rob04C5LM
Originally Posted by Jet-Jock
2001
* Smaller keyfob
That would be a "yes".
The '04s also got some good nuts and bolts differences, some of which have turned out to make some replacements/upgrades a bit cheaper for me than for older models. I'm sure there are just as many things I haven't found that will be more expensive to deal with. I like to buy the last model year of a particular body-style or platform. The engineers have usually worked out the major issues at that point, even if replacements are more expensive you're not as likely to need as many.
Old Apr 13, 2011 | 12:08 AM
Loverofcorvettes
Thanks everyone for the info, it was very informative. I love having this resource, thanks again.
Old Apr 13, 2011 | 04:30 PM
Loverofcorvettes
Default Thanks for all your info, it was very helpful.
Old Apr 13, 2011 | 06:21 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
That's funny..........
Old Apr 13, 2011 | 10:03 PM
dba4life's Avatar
dba4life
You also get an increase of 25ft/lbs of torque on a manual 2001+ C5
To Difference in 2000 to 2002 corvettes
