Rocker arm failure
Old Apr 14, 2011 | 09:52 AM
Torchred62's Avatar
Torchred62
Default Rocker arm failure
A friend of mine has a 2002 C5 and he recently went to change his oil and found small metal pieces in the drain pan. After a little reseach he found out one of the rocker arm bearings failed. My question is knowing this is fairly common with older LS1's what should he do to ensure a good repair? Just change the oil, replace all the rockers, what else?
Old Apr 14, 2011 | 10:48 AM
robert miller's Avatar
robert miller
I have a set out of my 04 will sell cheap 17,k miles on these. For sure put something diff if older c5 had a problem with them.. Robert
Old Apr 15, 2011 | 03:39 PM
Torchred62's Avatar
Torchred62
He has a new set of the replacement rockers. GM now uses the newer style rockers for all replacements. But his main concern was how to clean the motor to make sure there were no little pieces of rocker arm bearings thru out the engine to make sure a little piece does not find its way to an oil galley or some place it could harm the engine.
Old Apr 15, 2011 | 05:45 PM
Z06X's Avatar
Z06X
There's a conversion to replace those bearings with units that use a c-clip on the end to ensure they don't come apart. The problem of the bearings coming out is a fairly common and known issue.
To Rocker arm failure
