04 making me nuts
It has NO mods, bone stock 28k miles. automatic trans.
Any ideas?
Transmission calibrations aren't really my thing, but I am taking a shot at this and I may be completely wrong. These are just some of my thoughts, it's hard to really know with out seeing the car.
Factory transmission calibrations are set-up for comfort and durability over performance. That being said the car is set up to provide the driver requested power, but smoothly. There are several calibration points that are set to provide protection against damaging components as well. It's torque limited depending on what gear you are in and several other conditions like having traction control on or off. Another key point in transmission calibrations is its ability to adapt and anticipate driver input. If you just went on a WOT blast, it may hang the throttle open a bit and keep the shift points high and firm.
So my theory is it's possible that the conditions were not of the calibrations liking, so it restricted torque output. OR it did not anticipate a WOT condition so before it knew what you wanted it to do, it didn't take off like a bat out of hell.
Another possibility is within the engine's tune. Power enrichment mode, or WOT, is programed on a delay. Meaning you put your foot down, the PCM sees this, waits a moment, and then delivers. Once you are in PE mode it will stay for a bit until things settle down. Again, a tune could eliminate this delay.
Just some food for thought.
Any ideas?
You know we also have tourque management in the auto (in addition to AH and TC). If the car thinks you're gonna break something, it will retard the spark and you will get that "bogging" thing you are describing.
Not saying there's nothing wrong in anyone's specific case, but turning off AH and TC does not mean you are in complete control, its still a drive by wire system.
You may smash the pedal down and the throttle may only open 20% in some conditions (no direct mechanical linkage, you get the throttle open as much as the programming thinks is safe and some conservative restraint went into the programming for general purpose drivers).
